Question about Navman GPS
My navman 5500 doesn't show my present map area but every thing else seems ok can the cmap cards go bad? ive sprayed them with contact cleaner but doesn't do any good
SOURCE:
SOURCE: Navman 5500 tracker
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Posted on May 02, 2008
SOURCE: updated map card for my navman icn320?
you can get the updated map card here
http://www.37signals.com/svn/archives2/garmin_nuvi_350_insanely_recommended.php
Posted on Jun 12, 2008
SOURCE: Navman s30 3d 2009 map update is useless
You should be able to install your old map from the DVD/CD that originally came with your Navman - you don't need a Product Key for this, even if it prompts you for one.
It appears that the commercially available 2009 map for the S-Series does *not* cover the S30 3D, just the non-3D versions, although that's not at all obvious from what's on Navman's web-site, so you have my sympathies if you bought it expecting it to work...
Posted on Sep 29, 2009
SOURCE: navman 5500 gps backlight dim but set to max
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
solder a new wire to bypass the short.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
Posted on Sep 28, 2011
  • 26 Answers
SOURCE: no power under acceleration 2001 chevy impala,ive added injector cleaner , cleaned maf,also checked cat ,seemed good, also replaced map sensor
well it is a chevy, its always had that problem. Haha, just kidding. But, seriously, it can be something as simple as a clogged air filter. I did all that you did on a car I had, and then, I replaced the air filter that I thought was good (reusable K&N) and it ended up being that. Try the air filter. Either replace, or clean it.
Posted on Apr 14, 2014
Diplomat dishwasher recirculating problems
I live in an area with hard water. My spray arms get clogged with hard water deposits. Are you sure the spray arms are clear? Here's a map showing hard water areas in USA http://www.citriclean.net/why-citriclean/
Dec 29, 2013 | Dishwashers
I have a navman 5500i tracker ,the zoom isnt coming up far enough to show water depths and hazards by pushing the + - button .is there an easy fix? Thankyou Muzza
Just got the same one and same problem, I also have a 5505i and is only zooms in close when i put in the c-map chip and it zooms close in the chip area only?? now i have a chip for the 5500i and it zoomed in but only on the Texas part of the map, that is the chip it came with, but i live in Canada. Be carefull the c-map max chip for the 5505i is not compatible with the 5500i it needs c-map nt+ chip. 5500 chip is black 5505 is orange
Jan 19, 2010 | Navman Tracker 5500i GPS Receiver
Sep 17, 2009 | Navman NavPix N40i GPS Receiver
Zooming in on the 5500i there is more detail then it disappears
I had the same problem when I first started the Tracker up, but after rmoving and replacing the C+ card a few times, the details reappeared and have stayed ever since. I suspect a poor contact between the copper surfaces on the Tracker and the card. Steve
Mar 27, 2009 | Navman Tracker 5500i GPS Receiver
Navman 5500 tracker
Apr 24, 2008 | Navman Tracker 5500i GPS Receiver
Navman S50 wont load maps
Hi, my probelm is very similar I turn it on and it shows a laptop, usb connection and the navman with a usb cable connecting them together,it also has circle running back an fourth
Feb 08, 2008 | GPS
Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Jul 30, 2007 | Raymarine RL70CRC GPS Receiver
GPS reception
Navman in no longer offering map support for it's iCN 510. This means if there is a new road or community, this unit will not recognize it.
I am really mad about this. I spent $400 2 years ago for something that will not have anymore map updates. Here is there reply when I wrote to them about it. Class action suit anyone?
Dear Henry,
Thank you for contacting Navman Technical Support.
We do apologize for the inconvenience. Navman has decided not to release further map updates for these device due to changes in technology over the last year. We have changed the chipset1.gif and software1.gif platform and are unable to update this device. The Navman 500 series was released with an updated map version last 2005.
If you need further assistance, please do not hesitate to contact us, we'll be more than happy to help.
Kind regards,
Ofelia
Technical Support Team
Navman USA
C/O Mio Technology USA Ltd.
47988 Fremont Blvd.
Fremont, CA 94538
Office: +1 (866) 962-8626
www.navman.com
Jul 16, 2007 | Navman ICN510 GPS Receiver
GPS Logo
47 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
