I have called Tech support and they state its in the phone line as to why it wont pick up automatically. Called phone company and they state the line is fine. Any way to get this machine to answer that fax automatically?
SOURCE: Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
SOURCE: fax mach wont receive from other faxes
I'm sorry....Do I have this right? You say that another fax machine was hooked up on the same phone line and you have the same problem with that one. So the problem is related to that phone jack?
It sounds to me like there must be just the slightest amount of interference in the jack, interfering with the fax. They are far more sensitive than just a telephone. You could try a phone line filter.
SOURCE: I have a Brother Intelli 1270e. We cannot receive
pick up hand set. do you have dial tone? if not check connections.
SOURCE: My Canon MF4350D doesn't receive the fax
In fax/tel mode the machine recognize if it is call or fax it should work.Try without ans.machine and see.
Is tel line going into correct socket of fax? (Line not Ext.)
Is Fax set to auto answer or manual?
If you pick up line or press speaker button can you hear other fax sending if so press start and hang up you should receive fax, and you have just proven that machine is in manual receive mode!
I think you will find it will wake from sleep automaticly if setup correctly.
