SOURCE: Pairing LG Shine and Bluetooth HS850 unsuccessful
UGH I had such a hard time with this, because it isn't clearly explained.
So here is a solution that should work (it worked for me!):
1. Go to Settings, Bluetooth, and Go to the "Paired Device" menu and leave it open.When it asks to turn BT on, you can do so.
2. This is the part here that screws everyone up. Take the headset and press and hold the multifunction button. KEEP IT HELD DOWN! The light should turn on and stay on. While you are holding it, open the microphone. The light should have been on while you were doing this and still be on. If it didn't stay on the whole way try again from when the mic is closed.
3. Remember the "paired device" menu? Select "New" and it will auto search for the headset.
4. It should be found quickly. The headset (that you should still be holding down but with mic open) will blink, then your phone will ask if you want to pair with Motorola HS850. Say ok, then it will ask for passcode 0000.
5. The headset will blink and the phone will say it was successful, and ask if you want it to be turned on. Say yes and make a test call. It should be fine from there.
Hope it helps!
SOURCE: have been unsuccessful in pairing my motorola razr
Easy way to Unlock The Mobile.U can Use the site http://www.mobileunlockguide.com/ First For the Mobile Unlocking Process.
SOURCE: All bluetooth connectivity stopped with
The picture Im sending you is the information on your vehicle based on what I can get from General motors tech website to inform you if your intstructions in owners manual are unable to correct your situation.There really no way to quick fix the issue.here is the page information; Before reading note there are unavailable sections or links because it is pasted from a General motors page unavailable to public.
You are looking at a trip to General motors unfortunately unless you can find a shop with a tech 2 scan tool.
Circuit/System Description
The Bluetooth ® antenna is a small fixed antenna connected directly to the telematics communication interface control module and is used to send and receive signals from a Bluetooth ® enabled cellular phone. The antenna utilizes no cabling and is not external to the vehicle.
In order to use hands-free calling, the cellular phone must be paired to the vehicle. Up to five devices can be paired to the vehicle at one time, but only one can be connected at any given time. To pair a phone, the customer must know how to operate the Bluetooth ® functionality of their phone. The pairing process must only be done one time for each phone, unless that phone’s information is deleted. For safety reasons, the pairing process is disabled while the vehicle is moving.
Diagnostic Aids
The purpose of this diagnostic is to verify the ability of the telematics communication interface control module to pair to a Bluetooth ® device.
Before performing this test, verify compatibility of the cellular phone(s) the customer is attempting to use with the vehicle. Based on the cellular phone’s service provider and the manufacturer’s implementation of Bluetooth ®, not all phones support all available Bluetooth ® functionality. A vehicle and feature compatibility list will be provided via the GM Bluetooth ® website: http://www.gm.com/vc/bluetooth/
If the vehicle passes the following tests and a compatible device is being used, the concern may be due to a device malfunction or an incomplete/improper pairing attempt.
A Bluetooth ® test tool or equivalent can also be used to verify the ability of the customers cellular phone(s) to pair with another device.
Schematic Reference
OnStar Schematics
Connector End View Reference
Component Connector End Views
Description and Operation
OnStar Description and Operation
Electrical Information Reference
Circuit Testing
Connector Repairs
Testing for Intermittent Conditions and Poor Connections
Wiring Repairs
Scan Tool Reference
Control Module References for scan tool information
Circuit/System Verification
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure.
Control Module References for telematics communication interface control module replacement, setup, and programming
Hi Timothy
Noise on the same frequency (channel) as your bluetooth connection can inter fear with the connection process.
Check the IOS version you are running. Update if needed via WiFi.
Try outside, away from WIFI & microwave ovens & hotspots & other smart phones & devices in your area.
Turn off your Bluetooth on the iPhone.
Reset the iPhone by quitting all Apps then Hold down Top & Round button together for 5 seconds or more.
Restart your phone with top button (3-4 seconds)
Erase the old bluetooth connection name and restart the discovery routine to establish a new connection.
Last Resort..... Do a full restore or the iPhones IOS
If all else fails.... drop in to your Apple Store
Good Luck
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
