A detailed description of this procedure is found in the manual of your watch. You can find the right manual with the module nr. on the back of your watch (4 digit number in a rectangle)
The manual for your watch can be downloaded via the link provided below:
Timepieces Watches
SOURCE: turning off the alarm on the Casio Sea- Pathfindder SPF40T
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
SOURCE: I have a gold casio
You will most likely need to go to the "Alarm" setting mode to toggle the alarm on or off. On the back of the watch, there should be a number inside a rectangular box. This is the module (not model) name. The module is the "brains" of the watch. If you go to the support section of www.casio.com and look under watches/manuals, you will be able to input the module # and download the instruction manual for your watch as a PDF file.
