Red light is on only = new batteries in remote check for reset button on bottom or back
SOURCE: tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
SOURCE: Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
SOURCE: wii remotes will not stay on
1. Press the Power button on the Wii console to turn it on.
2. Remove the battery cover on the back of the Wii Remote you wish to sync up.
3. Remove the battery pack & install regular batteries.
4. On the back of the Wii remote press the SYNC button just below the batteries. The Player LED will blink.
5. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
6. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
7. Quickly remove the batteries and reinsert your Battery Pack.
8. Return to Step 2 for each other remote.
You may run into this issue any time your battery pack has a 0% charge left in it for a duration. Try to keep them charged to prevent it from occuring in the future.
SOURCE: remote control
I had the same problem. The problem is strange and seems to be with the receiver in the TV and not the remote control. The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV. This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote.
- Press and hold the red (ON/OFF) button for at least 1 min.
- Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
SOURCE: Remote won't turn on the system. Has new
Unplug the speaker plug and the power plug. Let it sit for a minute. Plug the speakers in and then the power and try again. Hope this helps.I have seen this many times and this is usually the solution.
