So get fixed
Testimonial: "No help what so ever. Why do you even bother!!!!"
so what answer were you expecting its broken by your description what you expect a magic chant that will correct it you know its broken and you post not a question but a statement about a broken start button you received the only help and answer you could get from that statement and dont know why you would even BOTHER have to post one on something so obvious
SOURCE: maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
SOURCE: nothing happens when I press the start button.
here is a list of things it could be. pull spark plugs check compression. all cylinders need to equal each other within five percent, and be over 100 lbs of compression. I don't know the year model but, some gp1200 comes with a security key pad. click here for a link to Yamaha, for the owners manual. it will give detailed instructions on how to reset code. last find the starter solenoid I have attached a picture.in the picture it has a number one marking the image. the discription at the bottom says starter relay assy A quick test of the starter is to jump across the leads. You need to be careful it will arc. best thing to use is a short screw driver. use the metal shaft of the screw driver to connect both threaded connectors on top.
SOURCE: i can not remove my beko wm5140w filter. it seems
pull - it is caked with sediment. it will come off.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: beko wm 5140 washing machine is starting its cycle
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: I require a operating manual for my beko wm5140w washing machineI
http://laundry.manualsonline.com/manuals/mfg/beko/wm_5140_w.html?idRes=16718058
A quick google search will bring up one online, otherwise check with the manufactuer for a printed copy. or download a PDF and take it to your local print shop
