SOURCE: My Blu-Ray BDP1590 Samsung freezes at the title
Try to reset system at Samsung support. To do this you just take disc out, hold the FF button down on unit until you see "reset" then select language. Turn system off then hold power button for 15 sec. Then restart system.
As far as Netflix you got to got to system, determine if you are using wireless or cable. You have to set this yourself.
You should also update your firmware here at http://www.samsung.com/us/consumer/tv-video/blu-ray/blu-ray-players/BD-P1590/XAA/index.idx?pagetype=prd_detail&returnurl=
You will see a support tab, which has your download on it. I would try the CD based download first.Download the file, unzip it, and burn it onto a CD. Then, with the unit off, and unplugged, plug it in, open the drawer and insert the disk. Close the drawer and see if it will read the new files. If not, then try the same procedure on the USB option.
Thank you!
SOURCE: TV turns on. I can watch my cable, enter netflix,
Theres a short in the power distributor. You should be able to pick one up for about $50-$80. Its a simple fix, unscrew the panel where your power cable plugs in, there should be 2 or 3 screws holding the connector to the main board, remove those and pull the distributor off and pop the new one on.
SOURCE: When I open Pandora internet radion under netcast
I'm having the same exact problem. Did you get your issue resolved?
SOURCE: Lenovo ideapad z575 running slow
I would start by cleaning the machine with CCLEANER free found at: http://www.filehippo.com/download_ccleaner/. Now what is running on your machine that is not needed, use CCLEANER ,TOOLS, STARTUP, to disable what is not needed to start at startup. I have no idea what is running on your machine but remember everything that is open will use memory and cpu power. look at Services and task manager , processes, for memory hoggs that are not needed. Get rid of TOOLBARS on browsers they are killers. Also install and run MALWAREBYTES free :http://www.filehippo.com/download_malwarebytes_anti_malware/ Take a look at this tutorial: http://www.computingunleashed.com/speed-up-windows-7-ultimate-guide-to.html
SOURCE: i want to update my netflix and hulu apps to the newer versions on my vizio E3D420VX TV
Updates will come from netfix and hulu. look for update option when on those sites.
Were you able to? i have the same TV and I want to download hulu and comcast stream.
