Panel frig temp showing 32 but temp reading inside showing 40 to 46
SOURCE: Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
SOURCE: Samsung french door ice maker
Check my solution here. The noisy sound is the swing arm trying to knock out some stuck ice.
http://www.fixya.com/support/t1141317-two_issues
SOURCE: GE French Door Frig control panel blinking temp #s
I had a very similar problem with our GE refrigerator. The main control board looked to be the culprit. I took out the board and did a visual inspection. Upon inspection I discovered that the (2) 470 micro farad capacitors were blown. I checked the power diode near these and it was still ok. I went to Radio Shack and picked up two 470 micro farad - 35V capacitors for and grand total of $2.60 and resoldered them myself. The refrigerator has been running great since. If you want to know more details email me and I will be happy to let you know what I know. I didn't want to pay $100 for a GE guy to replace a board either!
SOURCE: Freezer side tmp flashes/makes noise/inside back panel iced
The freezer side is off. The temp is flashing on the meter in front of the refrigerator. This is a Samsung RS2545SH. Does this freezer have a reset button or what shall I do.
