Daihatsu Terios is a low-engine (low-level) SUV developed by Daihatsu, and then finally became a Toyota Rush development project in 2006.
SOURCE: 3.3l dodge caravan, where to set timing chain marks
the top gear timing mark points at 6oclock...crank gear at 12 oclock
SOURCE: where are timing chain marks on the engine of
Please don't forget to rate:
Crankshaft and camshaft alignment marks—2.4L (VIN X) Engine
Camshaft and crankshaft alignment marks—Chrysler 2.5L (VIN N) engine
Timing belt engine sprocket timing—2.5L (VIN H) engine
SOURCE: 1999 Ford Expedition 5.4L Timing chain setup
Remove the two bolts, the timing chain tensioner and tensioner arm.
NOTE: LH shown; RH similar.
Remove the bolts and the timing chain guides.
Installation
CAUTION: Do not compress the ratchet assembly. This will damage the ratchet assembly.
Compress the tensioner plunger, using an edge of a vise.
If the copper links are not visible, mark two links on one end and one link on the other end, and use as timing marks.
If removed, install LH and RH crankshaft sprockets.
Position the tensioner arms and tensioners, and install the bolts.
SOURCE: nissan navara timing chain marks
I have a Nissan Nivara With the Z24 motor Fitting a new timing chain sprokets guides and adjuster Where does the camshaft numbers 1 2 and3 go
