Https://www.lg.com/us/mobile-phones/VS985/Userguide/097.html
How do I get my Android out of recovery mode?
Press and hold the Power key and the Volume up key for around three seconds, and then let go of the Volume up key, but keep pressing Power. You should see the Android system recovery options pop up at the top of the screen. Use the Volume keys to highlight the options and the Power key to select the one you want.Feb 18, 2018
https://www.digitaltrends.com/mobile/use-recovery-mode-android/
SOURCE: The Screen shows "welcome. Powering up....." and is stuck
Direct TV has been working on numerous software issues. Some patches have been downloaded for TiVo that in some cases have caused problems. In your case, it is more possibly an indication that the hard drive is not running and you have a possible hardware failure. When you rebooted and became stuck on the "welcome, powering up screen", it could be an indication of a software glitch or a hard drive failure. I would go with a hard drive failure. Since this is a Hughes Receiver like mine and you own it, you could try a drive swap with another TiVo drive out of a like receiver. If one is not available, you may have to purchase one. Pre-configured and initialized drives are available from www.weaknees.com. I have no interest in them, but that is where I buy Tivo pre-configured Hard Drives from. You can get replacement or upgrade Maxtor Drives preconfigured from them for this specific brand and model of TiVo DVR. A drive swap would be cheaper troubleshooting. There is also a possibility of a problem with the built-in IDE controller or the power supply on your receiver which can't be determined until you do swap out with a Known Good Drive to eliminate a hard drive problem. If you are able to swap it out and If the good drive works, then your old one has corrupted data and would need to be re-initialiaed and reloaded. If it is an older smaller (35 hour) drive, you would be better off with a new replacment since the loading is a somewhat lengthy process and must be done on a computer running the Linux Operating System.
SOURCE: Stuck on the Windows XP Welcome Screen
One of an important file needed to boot up your laptop, or your hardware is loose. Try taking out the ram and putting it back in.
SOURCE: FLY-YING F006 Only goes to the Welcome screen, how do i get past.
My sci phone keeps coming up invalid sim. Can anyone solve this?
SOURCE: Freezing on welcome screen
what can you explain please . because mine too is just restarting in the welcome screen ?
SOURCE: Our Toshiba RS-TX60 Tivo-DVD is stuck on 'Welcome'
Could Be a Bad Drive.
These units sometimes take a long time to boot.
Wait about 5-10min.
Replace Drive
