Computers & Internet Logo
Joe wilson Posted on Aug 14, 2018
Print from targus
Targus THZ634GL-52
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on Aug 07, 2008
SOURCE: Targus PAWM001 Mouse - How to connect it to my laptop
Yeah, I was kind of confused about this too. Apparently, on the base of the mouse, there is a red reset button. Press that, while simultaneously pressing the black reset button on the base of the charger. The laser light should becomes steady after a moment, indicating that the mouse is in sync with the laptop. If the laser is blinking, however, then the mouse is attempting to become synced. You may have to press the reset button multiple times. Hope this helps.
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Apr 25, 2009
SOURCE: Driver for Targus Webcam Model # AVC02EUK
You can find most drivers at www.driverguide.com.
If this information is a help to you please rate fixya oor one below that thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Joed911
JDTec
  • 4338 Answers
  • Posted on Jun 07, 2009
SOURCE: change batteries in a targus portable mouse
I found the user guide in French. It says to slide back the cover behind the Logo on top.
also found it in English:
Installing the Batteries
Optical Mouse
1 Remove the battery cover from the top of the mouse by
pressing the top center (over the Targus logo) and
sliding it back.
2 Insert the supplied batteries , making sure that the
positive (+) and negative (-) ends of each battery match
the polarity indicators inside the battery housing.
WARNINGS: When replacing the batteries, you may use
alkaline or other heavy-duty NiMH batteries. Never
combine an alkaline with a NiMH battery in a device.
Avoid mixing new and used batteries in a device.
3 Slide the battery cover back in to position until it “clicks”
firmly into place.
4 Turn on the mouse by sliding the on/off switch on the
bottom of the mouse to the “on” position.
The optical sensor, located on the bottom of the mouse,
glows red.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Anonymous
  • 100 Answers
  • Posted on Sep 22, 2009
SOURCE: Targus Bizcard Scanner PA570 driver
Dear Brother
here is the link to the original Driver from the manf.
http://www.targus.com/ca/drivers_manuals_archive.asp?sku=PA570C
i test it on my device and it work pretty will
thank you
if you want any info plz write to me
[email protected]
Anonymous
  • 29 Answers
  • Posted on Dec 14, 2009
SOURCE: Targus CD/DVD does not show in directory
try to use another usb cable for your external dvd drive>>>> then if it's not working again try to check the bios setup if the optical drive is enable. if the setting is disable please change it to enable>>> if still not work back on where did you bought it>>> maybe it is defective...
Testimonial: "Excellent advice. Quick response. Solved my problem on the first try."
Print from targus tablet
google targus with make model and serial and go to support/download and get user manual.pdf
10helpful
2answers
Windows 7 driver for Targus ACB10US1
your driver can be downloaded by using this pro tool: Driver Update Software for XP Vista 7 8. Have a nice day
Mike
Targus PA870 Universal Wireless Foldable Keyboard driver
you can visit this site for the driver of the targus keyboard u want
http://www.targus.com/us/product_details.aspx?sku=pa870u
would be glad to help u out
thank-you for quires
1helpful
2answers
Need driver for targus mouse amb04us win7
Targus Bluetooth Mouse Driver: Direct Download from Targus.com
Don't be mislead by the title of the file, the file covers any Targus Bluetooth Mini-Mouse.
Looking for driver for Targus AMB40US mouse
Go to this site:
http://www.driverfiles.net/Input-Devices/Targus/page,level2,485,20,resultpage2.html
10helpful
PAID MORE THAN I SHOULD HAVE FOR TARGUS TCG717 NOTEBOOK CASE
FixYa is a technical support site and does not supply Laptops or Accessories. Neither are we directly affililiated with Targus. You will need to raise your complaint directly with Targus Customer support at the following link
http://www.targus.com/us/content.aspx?page=contact
Many Thanks for using FixYa.
Top Targus Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
