SOURCE: blue tooth adapter and hs850 headset on my computer
Yes, you need the blue tooth driver. The one that comes with your blue tooth "toggle". Although my laptop said "blue tooth compatible" I still needed a toggle. They are fairly cheap to buy and go into a USB port.
SOURCE: blue tooth headset for nokia 3110c
You can purchase a universal bluetooth headset and then pair the device using the instruction manual that comes with the headset. This is a very easy process and all you need to do is make sure that the blutooth on your phone is switched on. When you turn the headset on, it should automatically pair after the first attempt.
SOURCE: Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
SOURCE: Can't bond Samsung bluetooth(WEP 200)with my Motorola A1200 Ming
Try this (from the manual)
2 Press and hold the Multi-Function button until
the indicator light turns on in blue
(approximately 8 seconds).
SOURCE: motorola h350 blue tooth headset microphone does not work
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
