I used to work for a safe company.
The solution to your problem is not nice.
You need to find someone with a 9 inch grinder and a metal cutting blade. Don't bother to try to cut the door off it is the strongest part.
If possible cut the back off. If not possible to get to the back start with the hinges if you know where they are, some hinges are concealed and are not where they appear to be.
This solution is messy dirty noisy and dangerous, that's what safes do to deter criminals.
If safe companies kept generic codes to open any kind of safe they wouldn't be,,,,,,,,,,,,,safe.
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
The cable lock should come with a small pronged key used to change the combo, if you lost the key you can try getting a replacement from HP.If not you will need to cut the cable and buy a new one.
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock.
With the Combination
Step 1
Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
Step 2
Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
Step 3
Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination
Step 1
Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Step 2
Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Step 3
Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination
Step 1
Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Step 2
Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Step 3
Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Step 4
Roll the dials until you have your new combination.
Step 5
Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals! www.alibaba.com$0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now! www.hostgator.com/1PennyRooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now! www.airconditionings.cnDownload Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now! www.facebook.comby Taboola Sponsored Links Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft RecipesSee Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
Do not open a lock that does not belong to you. It is against the law.
ABOUT THE AUTHOR
Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
I realise this is an old question, but...
Open the lock with the default combination (0-0-0-0)
At the insertion point you will see a raised ring to the right of the numbers. Turn this part clockwise (it has an arrow on it). Set the combination you want. Turn the ring back, anticlockwise. All done!
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
which is not the cryptoflex 1218 but is compatible anyway.
dont
hurt your fingers trying to depress the nodules as the diagram says
though. to my chagrin i discovered that they will turn easily if you
just push them around into place.
here are the instructions:
To set your own combination Your new lock is preset to open at 0-0-0-5 at the factory. 1. Open the lock by aligning the opening combination number to the Guide Points and pull out the Lock Post. (Figure 1) 2. Push down the two Reset Buttons simultaneously with thumb and forefinger, and turn counterclockwise until it comes to a stop. (Figure 2) 3.You are now ready to turn the dials to set your secret combination, such as a phone number, birthday, etc. 4. After setting your secret combination, turn the two Reset Buttons again by Thumb and Forefinger clockwise until it comes to a stop and back to its original position. 5. Verify your new combination before using your lock. Insert the Lock Post all the way into the Locking Port but do not turn the dials. Pull out the Lock Post. Your lock is ready to use. 6.The reset operation is now complete. Repeat steps 1-5 anytime you wish to change your secret combination.
dont
