The free arm metal cover is popped up on the right front corner not allowing the throatplate to sit flush so if I can take this free arm cover off I could possibly took it a tad to allow the end to completely sit flush again
Open the door on the bobbin area. At the very top left inside, there is probably a silver metal tab. If you push in on that metal tab, and the free arm should pop up.
Testimonial: "Not on the 140 on the older ones yes but not this model"
SOURCE: CV joint replacement
Generally no tool is required. If you use a "pickle fork" you will risk damaging the dust boot.
Have you tried whacking the spindle right near where the ball joint stud comes through? This will take a few good shots to break it loose.
Be careful not to hit the threads!
SOURCE: Maytag MAH2400A Will not drain
You may need to remove the screws holding the top and slide is back a hair to get to thos screws holding the control panel.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: How to remove the rear cover on a Bernina 1530
Hi, yes they just come off. I usually slide a small screwdriver behind them and gently pry them out.
There is also the cover on the handwheel that needs to come off by taking maybe a needle and prying that off from the edge. Then you will see a couple more screws. A small one and a big black one. There is also screws under the machine.
Hope I helped.
Rick
Bernina tech
SOURCE: Dish washer, Water leaks out of right front corner during first
it sounds like your machine is over filling. the gasket is not supposed to be under water. check the overflow float inside. it looks like a little hat or cone. it should move freely up and down. if it is stuck down, your machine will fill up too far and then leak. good luck
SOURCE: How do I remove the
see a plastic cap type thing attached to the seat where the rod of the headrest goes in feel this cap and you wil find a puch button press it and pul the head rest
