Question about Jacuzzi Home
Jacuzzi perfecta swp1-swp2 toilet, from out of nowhere water keeps running after flush. Fills up good but doesn't shut off. Any clues as to where to start? Thanks RD
    Top Expert:
  • Jacuzzi Master
  • 9,908 Answers
Leaky water valve or solenoid
Posted on Aug 19, 2018
5 Suggested Answers
SOURCE:
  • 81 Answers
SOURCE: We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
Posted on Jun 02, 2010
  • 349 Answers
SOURCE: Need a flush valve / float assembly for my one
1-800-891-0896 http://www.efaucets.com/f/jacuzzi-ez33-959.shtml
Check this web site out I hope it will help.
Posted on Jun 05, 2010
  • 349 Answers
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Posted on Jun 10, 2010
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
  • 51371 Answers
SOURCE: we have a Jacuzzi swp1 and swp2 it run's and will not fill up
Worn or defective flapper at bottom of tank
Posted on Dec 15, 2016
Testimonial: "here do we get parts"
We have a Jacuzzi swp1 and swp2 it run's and will not fill up
Dec 15, 2016 | Jacuzzi Home
After flushing the water run a long time before shutting off
Pull the top off to see the flap come down and seats properly over the hole. The water should fill up if this is correct. If it's off, water will continue to go into the bowl.
Oct 14, 2014 | Jacuzzi Bath Perfecta EZ33 959 White round...
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Aug 30, 2014 | Jacuzzi Perfecta White Round 2-Piece...
I have a Jacuzzi Perfecta SWP2 toilet. It worked good for a while , now when you flush it you have to jiggle handle to make the flapper fall.Lowes doesnt have a replacement so they sold me a Fluidmast
If you have to jiggle it it usually means the chain is longer then it needs to be so its getting caught on something, the jiggling just loosens it. Look inside when you flush to see whats happening. Metal chains also get wound up when too long and the same thing happens.
Aug 17, 2014 | Home
How to drain the water out of a perfecta jacuzzi toilet to replace flapper
shut off water supply. flush toilet. There will be a little left .You can vac out with shopvac if you must.
Jul 14, 2014 | Jacuzzi Bath Perfecta EZ33 959 White round...
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Jun 10, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Water level drops in bowl after it fills
If very little water is used on initial flush, The bowl is functioning as a tank for second thorough flush. The high water level cannot stay high in the bowl while in motion or you would have a mess ion start and stops.
May 28, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Replace your stopper at the bottom of the tank. While you do hat you should also just go ahead and replace the float. 25 dollars for everything and 10 minute worth of your time
Feb 14, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Home Logo
913 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
