It paired a couple of times but now nothing pairs with it
SOURCE: Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
SOURCE: HFBLU-LT100 pairing a second phone
Canadian Tire's HFBLU-LT100 (BK-600) won't connect to my SPH-m300 Samsung phone but I entry of the passcode (0000) about 20 times before it connect successfully.
SOURCE: Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
SOURCE: reset pairing mode to attach to different phone
With headset off... turn on bluetooth search from the phone.
Hold on button on headset until light turns solid blue. Then search for connection from phone. (code is 0000 (4zeros))
http://www.jabra.com/Sites/Jabra/ap-en/headsetsupport/pages/Knowledgebase.aspx?kbid=ee68a9ea-df26-4882-a7f8-a6cbcc42345c
SOURCE: I am trying to pair Visor Blade,Supertooth-Lite with mobile phone
Try holding down the green button release the mike then enter 0000 the phone should then pair. This worked for me so I hope it will work for you.
