Partial answer, right click anywhere on a blank area f laptop screen, go to properties an left click, you should see options for adding a external screen, add it. You can also locate the tiny screen emblem on upper keys on the laptop and press this key while plugging in the HDMI cord this sometimes will do the trick. Also get the source menu up on TV and choose HDMI 1 good luck.
SOURCE: PS3/HDMI issues
Hold your finger over the button on the far right of the PS3 until it beeps twice and the PS3 will cycle through it output settings and you should them be able to set up the PS3 through to the HDMI settings. Good luck. The answer above regarding the wrong cable is completely bogus.....your cable is fine.
SOURCE: My wii connection is black and white
You are connecting it into the wrong input. The Wii comes with a RCA cables that should go into the Video (composite) input that has yellow, red, and white. The component input will not work with the RCA cable input. Plug your Wii into Video1 and you should get the right colors. There should be another HDMI on the side of your TV, there are inputs located both on the back and side of the TV for your convience.
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
SOURCE: I am trying to connect my macbook pro computer to
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Testimonial: "Thank you for giving me another avenue to explore."
