Needle moving while trying to load bobbin and it wont spin
I assume you are trying to wind the bobbin. Sounds like the lever is not disengaging the needle head. If you \'ve had the machine a while, you may have the part under the bobbin winding area clogged up with thread lint and gunk. Get a penlight and try to see in the slit that the bobbin holder pokes through. You may need to take the cover off. If you do, then unplug the machine, remove the cover, and move the bobbin winder on and off and watch the other levers attached to it.
