Almost every app iuse freezes an stops chrome stops working an its extremely slow when it is working
SOURCE: my sound also crackles and I have a very slow windows startup
That's most likely a virus that's gotten into your sound device drivers. Try updating/reinstalling them. Try Dell's website or a search engine for exact drivers and how to install them.
SOURCE: Kenmore model 253.24 freezes, then stops freezing.
The thermostat cycles the freezer on and off. The cooling system runs as long as the temperature inside the freezer is higher than the set temperature. If the temperature inside the freezer is cold enough, but the thermostat cycles off, and doesn't cycle back on, the thermostat may be defective. If so, you need to replace it.
SOURCE: Facebook keep freezing up everytime
Try using facebook in a different browser and see if that solves the problem. You could have a bad addon or toolbar thats causing the browser to freeze up.
SOURCE: My Compaq Presario CQ62-225NR keeps
The most and perfect way to stop this is by cleaning your computer virus. Scan your system and remove all the viruses.
