Car Audio & Video Logo
Where is the reset button on soundstream vir-7840nr
5 Related Answers
Anonymous
  • Posted on Jun 23, 2009
SOURCE: I need the brake override for my soundstream VIR-7022
just ground the brake wire from the unit it will play video or tv any time then
Anonymous
  • 129 Answers
  • Posted on Aug 09, 2009
SOURCE: got a soundstream vir-5000 indash dvd player
Ground it.
Anonymous
  • 15935 Answers
  • Posted on Nov 05, 2009
SOURCE: what do i do when my soundstream vir-6500 screen
Send it in for repairs. It has likely had the ribbon cable damaged.
Thanks for using FixYa - a 4 TUHMBS rating is appreciated for answering your FREE question.
Anonymous
  • 93 Answers
  • Posted on Apr 27, 2010
SOURCE: lost audio/video remote for a soundstream VIR 8004
Here is a universial one im not sure if its what your looking for or not.
http://cgi.ebay.com/SOUNDSTREAM-Universal-Remote-Control-Model-R-1-/370359018370?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item563b1e2382#ht_2810wt_939
Anonymous
  • 3 Answers
  • Posted on Aug 04, 2010
SOURCE: by pass parkbrake on soundstream vir-5850
ground the park brake wire out
I have the vir-7022nr and when it's hooked up all it does is the power light flashes. What causes this?
Vir-7022nr. How do I calibrate? - Fixya
www.fixya.com/support/t25885028-set_calibration_vir_7022nr
Sep 29, 2015 - I use a Roland 540 printer, and I have replaced chips, motherboard, and encoder sheet. ... Sep 29, 2015 ' HP Photosmart 6520 e-All-in-One -... 0 Answers. photosmart 6520 power light flashing and has white screen had a ...
[PDF]VIR-7022NR - Soundstream
www.soundstream.com/manuals/2009/VIR-7022NR.pdf
Do not expose the product to water or excessive moisture. This could ... High De?nition Digital Panel with LED Back Light ... A new disc may have rough edges on its inside @- ... Flashing image ... power . . Insulate all bare speaker Wires from. (but no/low toucmng eaCh Other or touchmg each other and chassis ground.
Soundstream VIR-7022NR (vir7022nr) Single DIN 7" TFT-LCD
www.sonicelectronix.com > ... > In-Dash Car DVD Players
Soundstream VIR-7022NR • Single DIN 7" TFT-LCD Touchscreen ... iPod Ready:Power Acoustik IC-2 IPod connection cable required and sold ..... I have purchased many items from Sonicelectronix over the past while and I am fully .... All trademarks and trade names are the property of their respective trademark holders.
Monitor stuck vir-8300
Try pressing and holding the open/close button while pressing the reset . If you let up on the reset keep the open/close button pressed. I've heard that works but can't guarantee it. I haven't had this problem so I've never tried it. Might be a bad motor for the flip out. Hope it works for ya.
How to fix the13 pin wier card in-- Soundstream VIR-7840NR
Hola...Por que dices que el conector no te coincide??
Si es el que entra en el radio hay dos tipos, uno con 24 pines y otro de 28 pines, yo tube un problema igual y compre el conector adecuado en la pagina de power acoustik.
1helpful
Soundstream VIR-4100N
I BUY A SOUNDSTREAM VIR 4100N BUT WEN I WANT USE A GPS IN THE SCREEN SAY ERROR NO MAP IN SD CARD! WHAT I CAN DO?
Top Soundstream Car Audio & Video Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
leone C
leone C
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
