Cars & Trucks Logo
Brian McNichol Posted on Aug 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connected my Coleman propane stove to a tower connected to a 20lb tank. The stove regulator started expelling propane through a small hole at the top of the regulator knob. Is there a way to fix it?
I know it probably exceeded working pressure of the stove. If a replacement is needed, is there a step-down regulator that can be placed between the tower and stove regulator to reduce the pressure?
Steve Pack
Level 3:
  • Cars & Trucks Master 7,128 Answers
  • Posted on Aug 09, 2018
Steve Pack
Level 3:
Answers
7128
Questions
Helped
2275367
Points
27972
No there are no repair for regulator safety regs do not permit it. what is this tower can you go from propane tank to stove? type in search engine 2 stage regulator for propane tank. There be several returns. I personally would not buy bottom end regulator.
Amazon com Camco 59333 Horizontal Two Stage Propane Regulator with POL...
5 Related Answers
Anonymous
  • 84 Answers
  • Posted on Oct 31, 2008
SOURCE: 98 VW Window Regulator
Do you have the metal assebly completely in front of you? And you've made sure all the cables are passed the same. If yes there should be an arrow type area on each pulley? Also each pulley should have a smaller and a larger area?
Anonymous
  • 4669 Answers
  • Posted on Mar 11, 2009
SOURCE: fuel pressure regulator
Have you checked the fuel pressure? If it is high and fuel is not returning, the regulator is bad. If it is low and fuel is not returning, the pump is bad.
Anonymous
  • 92 Answers
  • Posted on Mar 23, 2009
SOURCE: fuel pressure regulator had no vacuum line connected
another engineers wet dream. think of it this way . what is normally in the intake when the engine is running.. answer vacume, hence the regulator gets its vacume without a hose connected to it as its already in a full time vacume chamber.no hose required . ps be carefull to seat the regulator and o rings securely into the housing befor you reattach the secureing metal clip.
good luck chris
Anonymous
  • 39 Answers
  • Posted on Apr 03, 2009
SOURCE: Water leaking from top of expansion tank.
have you replaced the bleeder screws? and the expansion tank cap they both have O-rings that compress and will fail over time also check the hose at the top of the exp tank it also has o-rings inside it
Anonymous
  • 84 Answers
  • Posted on Oct 26, 2009
SOURCE: 1998 pontiac sunfire leaking coolant from big pipe
if its the pipe on the engine then its the thermostate housing, if its in the front it would be th top of your radiator
Testimonial: "Thanks for your help."
I have a 2014 z930m that is fueled with propane. It runs good for a short time then it starts to lose power... like it not getting enough fuel... the regulator gets all frosted over... is that normal?
Could be!! Propane has to have room to expand. But when it does expand it gets cold. The fuel draw from your motor is more than the tank can provide. Sometimes it is because the tank is to full and sometimes the weather is to cold. Get a heating jacket and keep it around 70f. If it still ices up might start looking for a new regulator
1helpful
2answers
Small vacuum lack were could it be. Can't Fi do it
You use an Evap System Smoke Machine,
to find small leaks
Truck runs on propane does not start
Are you familiar with the propane injection system? If so can you tell me what tests you have run so far and what was inspected? Do you have a fuel type selector switch (to choose between Gas and Propane)?When did this problem start and what is the temperature outside? Propane will not convert from liquid to vapor fast enough, if it is too cold outside. Inspect the plumbing between the intake and the regulator. If there is a leak in the plumbing. The diaphragm inside the regulator will not move or open (to let propane flow to the engine). The regulator can malfunction if it becomes clogged with sludge from the propane. They sell a product that can be added to the propane tank. It is used to keep the fuel system clean. Please write back. If you have more details or information I would like to help. Good luck.
1998 discovery motorhome turned on propane at tank no gas at stove.is there a another shut off valve
It can take a while for the propane to get to the stove. ( 20 seconds maybe ) All the air has to bleed out of the line first. Also , if you have 2 tanks , there could be a selector switch on the regulator where the 2 tank hoses come in , that has to be selected to the tank that you have opened the valve on.
Turned on propane at tank get no gas at stove is there a another shut off valve
Gas could take 10 - 20 seconds to get to the stove. Air has to bleed out of line. Also if you have dual tanks , there could be a switch on the regulator to select which tank you want to use.
Engine diagram 96 vw passat vr6
PCV valves aren't common on European cars, instead they regulate vacuum flow by connecting a small diameter hose to a very small hole in the intake manifold or throttle body.
The other end of the hose is typically connected to the top of the engine at the oil mist and flame trap which is usually inside one of the cam covers. The main engine crankcase breather hose typically also connects there and sometimes is connected to the air cleaner side of the air intake and sometimes directly to the air filter housing.
The small hole generally needs checking during maintenance as they frequently become blocked. The hole is something like 5/64 inch but mostly it is beneficial to enlarge it just a little, say to 3/32.
Sorry can't advise you about the diaphragm valve...
1helpful
2answers
2004 Chevy Tahoe check engine light came on...went to Auto Zone and this is the readout: rich or lean condition on one engine bank only. this is for fuel trim bank one, next ECM has detected a rich or lean...
Yes and no. The climate change may have reviled a problem you didn't know was there. I'd say the intake gaskets are bad and are sucking air. And now that you are in colder weater the gaskets shrink and **** air.
That or you have a weak fuel pump. But I'd have it checked for vaccume leaks (the intake gaskets), first.
On my 98 deville a hose running from the coolant top is not connected to anything is it suppose to be like that
I believe you are referring to the coolant overflow bottle. If this is the case then yes it is NOT connected to anything. It is to expel excess coolant in the event that the pressure in the cooling system reaches a predetermined pressure, the cap will release the coolant in a controlled manner thereby filling up the overflow bottle and expelling the pressure along with coolant. This is to prevent coolant from spraying on the engine and starting a fire due to the high temp of the engine.
3helpful
2answers
1999 jeep cherokee do you have to remove the fuel pump to replace
The combination Fuel Filter/Fuel Pressure Regulator is located on the fuel pump module. The fuel pump module is located on top of fuel tank.
The filter/regulator may be removed without removing fuel pump module although fuel tank must be removed.
REMOVAL
  1. Remove fuel tank. Refer to Fuel Tank Removal/Installation.
  2. Clean area around filter/regulator.
  3. Disconnect fuel line at filter/regulator. Refer to Quick-Connect Fittings for procedures.
  4. Remove retainer clamp from top of filter/regulator. Clamp snaps to tabs on pump module. Discard old clamp.
  5. Pry filter/regulator from top of pump module with 2 screwdrivers. Unit is snapped into module
  6. Discard gasket below filter/regulator.
    1. Before discarding filter/regulator assembly, inspect assembly to verify that O-rings are intact. If the smallest of the two O-rings can not be found on bottom of filter/regulator, it may be necessary to remove it from the fuel inlet passage in fuel pump module.
    INSTALLATION
    1. Clean recessed area in pump module where filter/regulator is to be installed.
    2. Obtain new filter/regulator (two new O-rings should already be installed)
    3. Apply a small amount of clean engine oil to O-rings. Do not install O-rings separately into fuel pump module. They will be damaged when installing filter/regulator.
    4. Install new gasket to top of fuel pump module.
    5. Press new filter/regulator into top of pump module until it snaps into position (a positive click must be heard or felt).
    6. The arrow molded into top of fuel pump module should be pointed towards front of vehicle (12 O'clock position).
    7. Rotate filter/regulator until fuel supply tube (fitting) is pointed towards front of vehicle (12 O'clock position).
    8. Install new retainer clamp (clamp snaps over top of filter/regulator and locks to flanges on pump module).
    9. Connect fuel line at filter/regulator. Refer to Quick-Connect Fittings for procedures.
    10. Install fuel tank. Refer to Fuel Tank Removal/Installation.
WARNING: THE FUEL SYSTEM IS UNDER CONSTANT FUEL PRESSURE EVEN WITH THE ENGINE OFF. THIS PRESSURE MUST BE RELEASED BEFORE SERVICING FUEL TANK .
Two different procedures may be used to drain fuel tank (lowering tank or using DRB scan tool).
The quickest draining procedure involves lowering the fuel tank.
As an alternative procedure, the electric fuel pump may be activated allowing tank to be drained at fuel rail connection. Refer to DRB scan tool for fuel pump activation procedures. Before disconnecting fuel line at fuel rail, release fuel pressure. Refer to the Fuel System Pressure Release Procedure for procedures. Attach end of special test hose tool number 6541, 6539, 6631 or 6923 at fuel rail disconnection (tool number will depend on model and/or engine application). Position opposite end of this hose tool to an approved gasoline draining station. Activate fuel pump and drain tank until empty.
If electric fuel pump is not operating, tank must be lowered for fuel draining. Refer to following procedures.
FUEL TANK REMOVAL
  1. Disconnect negative battery cable at battery.
  2. Release fuel system pressure. Refer to the Fuel System Pressure Release.
  3. Raise and support vehicle.
  4. If Equipped: Remove fuel tank skid plate.
  5. Remove 4 fuel hose shield mounting bolts and remove fuel hose shield from body.
    1. Remove fuel tank fill hose and vent hose clamps at fuel tank filler tube. Remove both hoses at fuel filler tube.
    2. Remove exhaust tailpipe heat shield mounting bolts and remove shield. CAUTION: To protect fuel tank from exhaust heat, this shield must reinstalled after tank installation.
    3. Place a hydraulic jack to bottom of fuel tank. WARNING: PLACE A SHOP TOWEL AROUND FUEL LINES TO CATCH ANY EXCESS FUEL .
      1. Disconnect fuel supply line from fuel extension line near front of fuel tank. Refer to Fuel Tubes/Lines/Hoses and Clamps. Also refer to Quick-Connect Fittings for procedures.
      2. Disconnect EVAP canister vent line near front of tank.
      3. Disconnect fuel pump module electrical connector (pigtail harness) near front of tank. Harness connector is clipped to body.
        1. Remove two fuel tank strap nuts. Position both tank support straps away from tank.
        2. Carefully lower right side of tank while feeding both fuel hoses through access hole in body. Fuel Tank Full And Not Drained Using DRB Scan Tool: To prevent fuel loss through hoses, keep left side of tank higher than right side while lowering. Do not allow hose openings to drop lower than top of tank.
        3. Continue lowering tank until clear of vehicle. Place tank on floor with left side (hose side) higher than right side
          1. Drain tank by removing fuel fill hose at tank. Fuel fill hose is largest of 2 hoses. Insert the drain hose (from an approved gasoline draining station) into hose opening. Drain tank until empty.
          2. If fuel pump module removal is necessary, refer to Fuel Pump Module Removal/installation for procedures.
          INSTALLATION
          1. If fuel pump module is being installed, refer to Fuel Pump Module Removal/installation for procedures.
          2. Install fuel fill/vent hoses to tank fittings. To prevent hose from kinking, rotate each hose until index mark on hose is aligned to index tang on fuel tank.
          3. Install hose clamps to hoses. Position clamps between index marks on each hose.
          4. Position fuel tank to hydraulic jack.
          5. Raise tank into position while guiding fuel fill and vent hoses into and through access hole in body.
          6. Continue raising tank until positioned to body.
          7. Attach two fuel tank mounting straps and mounting nuts. Tighten nuts to 10 Nm (90 in. lbs.) torque. Do not over tighten nuts.
          8. Install both fuel hoses to fuel fill tube. Tighten both retaining clamps.
          9. Position fuel hose shield to body. Install and tighten 4 mounting bolts.
          10. Connect fuel pump module pigtail harness electrical connector near front of tank.
          11. Connect fuel pump module supply line near front of tank. Refer to Quick-Connect Fittings for procedures.
          12. Connect EVAP hose near front of tank.
          13. Install exhaust tailpipe heat shield.
          1. Install fuel tank skid plate (if equipped).
          1. Lower vehicle and connect battery cable to battery.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
