If u have drip pan on bottom of dishwasher it could possibly be it's sensing water on bottom of it u will need to slide unit out about half and look inside into dripping pan it's easy to get to it from left side if water is there try to clean out so tha star foam nice and dry make sure turn off power first then after all try to find a leak by running unit wale is still out and watch
SOURCE: Neff dishwasher continuously attempting to pump out water
I have just encountered the same problem on my S5433 XO GB/13. Did you manage to get a solution.
SOURCE: Inlet/outlet light comes on
Machine is possibly not filling with correct amount of water if this light comes on early in the cycle
SOURCE: Pump won't stop draining
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
SOURCE: bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
