First, I'm not a Samsung representative.
* Check your warranty. Call for support;
* Contact;https://www.samsung.com/us/support/home-appliances/refrigerators
*** The following is for information only.***
* The symptom of melted ice and water dripping from tray is usually caused by several things;
* Most common is ice build up in freezer coils. This happens every time the door is opened. Ice builds up on coils but is normally removed during a daily defrost cycle.
* The cycle may be unable to defrost all ice due to bad air circulation. Usually caused by rubbish blocking fan intake (bottom of freezer tray or wall.) Overloading food may cover the intake.
* Remove all food from freezer. Check for fan blockage. There should be a steady flow of cold air. If not then your freezer needs to be defrosted.
* Defrost by moving all frozen food to fridge side or cooler. Unplug fridge and open freezer door (drawer). Allow room air to circulate into the freezer. Use a house fan to blow air into freezer. (DO NOT use Hair dryer! It will damage panels.)
* Check and remove melted ice water. Check inner panels of freezer. Once defrosted the panels will be room temperature to the touch. There should not be any condensation or coldness to the panel. If it's still cold then keep defrosting.
* Once the water stops dripping. then close freezer doors.
* plug in freezer and wait 5 mins. Check freezer if inside is cold and the air is blowing cold. Reload freezer with food, take care not to overload or cover fan intake. Monitor for 2 days.
* Cleaning (Official); https://www.youtube.com/watch?v=AooBAPlk-Ts
* French door drawer; https://www.youtube.com/watch?v=_ZYLIRN_pk0
* Removing trays; https://www.youtube.com/watch?v=VxTliAhbr14
* Cleaning the back with a vacuum cleaner; https://www.hunker.com/13419629/how-to-clean-samsung-refrigerator-coils
* Freezer not blowing air or not cold? Bad fan, thermostat, pump. Call for service.
Aloha, ukeboy57
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
SOURCE: amana side by side ice dispenser leaking water
Take the ice maker out and look at the mold. If the coating is flaking off then that is where it is leaking. Will need to replace the ice maker.
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
SOURCE: ge profile refrigerator slow water dispenser
Have had problem with slow water dispenser in GE Profile refrigerator
for two years. SOLUTION IS TO INSERT A THIN PLASTIC OR BRASS WASHER. The washer
must have a hole large enough go over the center post / plug with the two O
rings but not so large it interferes with the seating of the filter. The objective
is to fully depress the little black valve piece. The little ramps on the new
filters do not fully engage the valve and thus the water trickles out. Volume
increased from one cup per 20 seconds to 1 cup per 10 seconds, double the flow.
Washer 1 mm thick will do the trick (about a dime thickness). I used a thin
brass washer which barely fit the center post, had to remove O rings to get it
on. (Re-install O rings.) The outer diameter of the washer was just enough to
touch the little black valve nub. If
this works for you please repost and pass the word.
