Cars & Trucks Logo
f
fred walker Posted on Aug 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a 2005 ford expedition with 5.4 l eng its throwing code u1900 . what is this
Have changed master cyl. brake booster,rear calipers all four brake hoses.i have tested ALBLconnector resistance to dash unit
Jeff Armer
Level 3:
  • Ford Master 15,575 Answers
  • Posted on Aug 08, 2018
Jeff Armer
Ford Master
Level 3:
Answers
15575
Questions
Helped
7100830
Points
73899
U1900 CAN Communication Bus Fault Vehicle Security Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault 4WD Control Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Parking Aid Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error DSM REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Instrument Cluster If the 4X4 light is not flashing at key ON, REFER to Section 418-00 .
If the 4X4 light is flashing at key ON, REFER to Section 308-07A . U1900 CAN Communication Bus Fault-Recieve Error Power Liftgate Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Stability Assist Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Air Suspension Module REFER to Section 418-00 .
which module won't communicate ? need a up scale scanner to communicate with all the modules on the vehicle. Do you know what C.A.N - controller area network is ? Serial data bus (network) All the modules on the vehicle share data on the network . U code's indicate a problem with the network .
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on Dec 17, 2008
SOURCE: 96 ford e350, brake pedal goes to the floor when running
Check for fluid leaks, possibly rear brake cylinders. has anything else been replaced prior to this concern?
Anonymous
  • 68 Answers
  • Posted on Apr 26, 2009
SOURCE: Rear brakes on 2005 ford 500
On my Chevy, I use a prybar between the rotor and the caliper to retract it a little, once it's off, I use a 6-in. C-clamp to fully retract it.
Make sure the reservoir doesn't overflow!
shocktroop40
John DeCosta
  • 155 Answers
  • Posted on Aug 11, 2009
SOURCE: BRAKE BOOSTER?
A bad brake booster will result in a hard brake pedal, stiff and more effort required to stop the truck. Here are my questions to you, first, you said you replaced the master cylinder, did you bench bleed it before you installed it? If not, there IS still air in it, regardless of how much you bleed the brakes at the wheels. Second, when you bled the brakes, after changing the calipers and master cyl., did you also bleed the proportioning valve? Sometimes air can get trapped in the valve, and its almost impossible to get it out bleeding just the wheels. And lastly, when the brake light comes on, does the abs light also come on with it? Air can also get trapped in the abs control module too.
Jose Luis Gonzalez
  • 25 Answers
  • Posted on Apr 24, 2010
SOURCE: brakes dont work, changed master cylinder,
check for air in the lines ..bleed the air out in this tire order LR, RF, RR, LF, i hope u bleed the master cylinder ..che if the bacuum to the booster is good
Mike
  • 4383 Answers
  • Posted on Mar 03, 2011
SOURCE: 99 ford explorer brake pedal goes to floor.
Not likely that the booster is an issue. The booster would not be able to overcome the brake fluid compression.
First open and inspect all brakes for leaks, adjustment, etc. Check all brake lines.
So if no leaks, did the fluid go low in the MC? If so, pad consumption would eat more than a MC reservoir of fluid, and not require MC replacement, but rebleeding and top up of fluid. If the pads are worn, and you replace them, often this will expel air back through the MC.
If you determine the MC is faulty, bench bleed the new one before install, or you will have lots of problems getting air out....
2answers
Why is my 97 expidition losing brake fluid. I cant locate where it's coming from but as soon as I put it in it runs out
It could be running out the front of the master cylinder into the brake booster. Unbolt MC and ease it back to see if fluid is present. If not, check rear brake drums.
2001 Silverado 2500 HD Why Rear brakes don't work after I installed new hydro-boost power booster, master cylinder, calipers, and pads. I bled master cylinder before installing, and brakes beginn
Hello Patricia,
Have you checked the master brake cylinder reservoir for brake fluid loss?
I don't suspect the master cylinder as you have replaced it... but am more suspect of a leaking brake line or fitting which should have
been discovered when you had the system bled.
The only time I ever had a rear brake problem with a 2500 series Chevrolet was due to seized rear brake caliper guide pins...as your calipers are also new that is not your problem.
If your brake pedal feels spongy and travels to the floor board you have air in the system, a brake fluid leak or a failure in the power steering system, such as a broken hose, broken power steering pump drive belt, or failed pump, would result in a loss of pressure to both the hydro-boost and steering.
Find more information here:
. Hydro Boost Power Assist Systems Operation Diagnosis and Repair
3answers
All of a sudden i have spongy brakes on my 92 f 250. changed master cyl and booster. and rubber brake hoses. still spongy and nothing is leaking.brakes went from being good to spongy in one...
Check the rear wheel cylinders? Was anything leaking at the master cylinder? Does it have ABS?
Check the front caliper slides are free. Check the front caliper pistons for leaks as well. This is all assuming you bled the brakes(all 4 wheels) properly after all that replacement! You're getting air from somewhere for sure or if it has ABS, the pump may have a problem.
2helpful
Would like to see brake digram of 1995 ford f-250
Item Part Number Description 1 2B120 Disc Brake Caliper 2 2140 Brake Master Cylinder 3 — Manifold Vacuum Source 4 2365 Power Brake Booster Check Valve 5 2005 Power Brake Booster 6 13480 Stoplight Switch 7 2455 Brake Pedal 8 — Fluid Level Indicator
(Part of 2L454) 9 11572 Ignition Switch 10 2261 Rear Wheel Cylinder 18fb197.gif
I have a brake problem, replaced front and rear and the master cyl. still get metal to metal sounds. brakes fail after used for awhile. After sitting for 5 min. not running the brakes are back. HELP
recheck the entire braking system, look for bad wheel bearings, make sure calipers are free floating, rear brakes are adjusted, parking brake releases ok, vacuum booster holds ,
2answers
Ford f250 diesel . front brakes come on when driving, don't have to use brakes. changed all calipers and hoses. if i bleed the calipers then they will start to release, sometime you can hear the brake...
sounds like a bad master cylinder, next time brakes are locking up , open bleeder screw and see if that releases brake at that wheel if it does then replace master cylinder, good luck.
3helpful
How do I install a brake booster on a 2003 Ford Expedition Eddie Bauer with no ESC package? Do I need to bleed anything before removing the part?
disconnect the neg batt cable,loosen clamp and disconnect air cleaner outlet tube and resonator from the air cleaner. 2.disconnect maf sensor connector. 3.lift air cleaner assy from tray and position aside. 4. remove screws from power steering resevoir, and position aside. 5.disconnect brake fluid level sensor, and if equiped brake pressure switch. 6.remove the two mounting nuts holding master cylinder, position master cylinder aside (DO NOT LOOSEN LINES ON MASTER CYL). 7.remove mounting bolts for degas bottle and postion aside. 8.if equiped diconnect wiring at the pedal position sensor. 9.relaease clamp and disconnect hose. 10.remove the pin, washer, bushing and switch, disconnect pushrod. 11.remove the nuts and brake booster, to access nuts fold back sound insulation. reverse procedure to install.
1helpful
2answers
Bleeding brakes
always bleed front driver side first, front right,left back
right back.
make sure you always have oil in the master
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
