SOURCE: CUTTING OFF
Ok What is probably causing the problem is an internal error inside the vacuum. What I recomend you to do is take it back where you bought it and tell them what ever is wrong with it.
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!
Hope it works! Tell me if you have any questions later on!
SOURCE: MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
SOURCE: draper dhs80i space heater cutting out after 25
Does this heater have a fan,forced heat? If so, the unit will shut down if the fan is sluggish or stops. It could be getting too hot or the rhermal safety is weak.
SOURCE: where is used toner bottle on aficio 240w
You must remove two panels on the right side of the machine. Remove the top one first (two screws), then the lower panel (two side screws and one in the back). Unplug the wire before trying to remove the bottle.
