Hello, Krystal -
It appears that "Universe of Imagination" / "Imaginarium", the maker of the Mountain Rock Train Table and related toys, was a proprietary trademark / brand name of Toys "R" Us, which has declared bankruptcy and has gone out of business this year (2018), at least in the USA. Canada, United Kingdom, and Australia. Toys "R" Us stores in other countries (mostly countries in parts of Asia, it seems) appear to be operating under new ownership.
You will probably only be able to find parts through resale businesses, including online sellers such as eBay, Amazon, Gumtree, etc.
Best wishes.
I am needing to order 2 trestle support for the train track in the instructions it is part N
The
Engine and Automatic Transmission (not applicable to manual
transmissions) in this vehicles drive train are fully electronically
controlled by a computer called the PCM and TCM (Power Train Control
Module, Transmission Control Module). When a problem like this or
other drive-ability related problems occurs the computer stores a
record of the problem (there are of course some exceptions to this,
like the fuel pump, engine coolant temperature sensor and MAF sensor
for instance) in the form of a fault code in its memory, to read
these fault codes you must have the systems memory scanned with a
special tool. Once the fault code(s) are read you then must perform
the appropriate diagnostic testing to find and resolve the problem(s)
DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED
THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT
MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for
correct spec for your make and engine type.
email: [email protected]
tel: (800) 933-0771
fax: (877) 933-0771
M-F, 8:30am to 5:00pm cst
