You will be able to get the answers from Haier support in your country. We are Fixya, not them.
It sounds like a control board fault. You can try a reset. Turn it off at the breaker for 2 hours. Switch it back on and wait 5 minutes before turning the unit back on with the remote.
If your 18 cubic foot Haier refrigerator is not getting electricity to the bottom fan, there could be a few different issues causing the problem. Here are a few things you can check:
Check the power supply: Make sure the refrigerator is properly plugged in and that the outlet has power.
Check the fan: Make sure the fan is not blocked or damaged and that it can turn freely.
Check the fan motor: If the fan motor is not working properly, it could cause the fan not to turn on.
Check the control board: If the above steps do not resolve the problem, the control board may be faulty and will need to be replaced.
Check the wiring: Make sure all the wiring is properly connected and not loose.
Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too high, the fan will not turn on.
Check the compressor: Make sure the compressor is running and not too hot to the touch. If the compressor is not running or is hot, it may be faulty and will need to be replaced.
If you are not familiar with any of these steps or if the problem persists after trying these solutions, it's best to contact the manufacturer or a professional for further assistance.
did you change the oil in it recently. the injectors are controlled with oil pressure. get an oil filter from ford with the upper housing. if you just changed the cartridge it could be causing your problem.
The wires usually just have connectors that push on/pull off. Some capacitors run the fan and the compressor and have 3 different terminals. It is very important to make sure the wires get put back on the right terminals on this type. You can find a capacitor at a local heating and air store.
If you're sure that the AC outlet in hot then it may be in defrost mode, in which case leave it plugged in for 45 minutes and it should cycle on, or the contacts inside the thermostat that turn the power on when they close, are burnt and need cleaned or replaced. Go to www.haieramerica.com/en/asset to find your manual.
best bet would to be to buy a plug that matches your receptical.....this is somthing you do not want to monkey with as if not wired right could turn your dryer into a fire hazzard. white to white green to green black to black and the other wire goes to earth ground for like trailer houses and modular homes.
HEY< the only thing to tripp the breaker is commpressor pulling too many amps due to running hot by not getting rid of enough heat thru the back coils. I bet the inside of the back coils are getting plugged up! Thank-you-very-much!
Try unplugging the machine, waiting a couple minutes, then holding down the power button as you plug it back in. Hopefully you will hear a "beep". Then unplug it again, wait a couple minutes, and plug it back in.
This procedure works for clearing the "E1" code from some of the Sharp models, so maybe you will get lucky and the same manufacturer made the control board in your machine!
Couldn't hurt to try it out. ;)
