Hello OP>
no symptoms stated at all. nor OS.
or task or job stated, (reload OS, or boot to other media?) what?
the boot menu is in BIOS, the manual is on line at Lenovo.
https://download.lenovo.com/pccbbs/thinkcentre_pdf/m73_tower_ug_en.pdf
Lenovo calls this the setup program it is just BIOS running.
F1 is the key to hammer at power on to enter BIOS.
page 93 covers that clearly. F10 is save setting as the pages state.
BIOS runs even when all boot drives are missing even unplugged
but not recover mode. F12.
yes use a real keyboard, to use BIOS , and if one USB port is dead
under bios, try others for sure USB2 ports , not USB3.
if you or others set a BIOS password, BIOS is locked.
a whole other matter, that must be stated under symptoms.
This can depend on your OS. For slower booting systems, press and release F12 repeatedly after pressing the power button. Release the button when you see the Choose Boot Device screen. Select the boot device and press Enter. (Note: some systems may not boot from all USB devices or CD/DVDs if they are set for a type of secure boot (UEFI).)
With some systems, you may need to enter the BIOS setup utility to allow the system to boot from a specific device. Try pressing F1 repeatedly after pressing the power button until you hear a lot of beeps or a splash screen. If there is a password for the setup utility, you'll need to enter that password. If you reach the Windows lock screen or the desktop, you missed the timing. Under Windows 10, go to the power icon in the Start menu (on the lower left). Press shift and click Restart. You will see an option for entering the BIOS on restart. Select this and wait. Once in the Setup utility look for the boot menu. You can change the order of the list. Press the correct buttons for save and exit to boot to the desired device.
I hope this helps.
(Note: some wireless keyboards may not work in the setup utility. Make sure that a wired keyboard isn't plugged into a USB 3.0 port if you need to load a USB driver to enable the port.)
SOURCE: my computer has been locked
U can reset boot menu password through removing BIOS battery and than switch on the system it will clear or some boards are with jumpers u can check CMOS clear from 1 to 2 for clear 2 to 3.try it.
SOURCE: my pc is Lenovo.. when i click the on button.. it
Welcome to Fixya
Turn off the computer then keep on tapping F12 key. This will give you options where you want to boot the computer. Select your Harddrive then press enter. Computer should boot up now to windows.
Please let me know if you have further questions.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
