All the other buttons and functions seem to be working fine. Please help! It's so frustrating!
SOURCE: 3 buttons on Keypad don't work
If You haven't already, open the phone remove the battery and SIM. I believe you can also remove the front face plate and key pad. Make sure the contacts behind the key pad are dry as well as the underside of the pad itself. Leave the cover and face plate off to allow to dry for as long as possible. If the phone was too wet it may not recover. If it does not you will have to replace it. The cheapest option is a go phone. You can get the Nokia 6010 refurbished online at Cingular for $29.95 and use your current SIM and will be good to go. When you order You will need to select a go phone plan but you do not need to activate it. Good Luck
SOURCE: Touch Screen not working
ı have problems about wıth my touch screen. ıt does not works sometımes.
ı have to restart my phone to make ıt work . can ı do somethıng more?
SOURCE: Microsoft Wireless Laser Mouse 6000 (Model 1052):
Normal
0
Go to Control Panel and click on the Mouse icon. Then
the mouse properties will appear showing the mouse buttons. Put the pointer on the left button and then go to the drop down and make sure the buttoon is set properly.
Hope this helps. Bud
SOURCE: setting the VAT calculation function
Press and hold SET button untill set appeares.
Presa TAX RATE batton, enter requred tax. Press set button.
Job done!
SOURCE: Unlock a Honeywell Thermostat
here is the link to get a manual for your particular theremostat.
http://yourhome.honeywell.com/yourhome/CMSTemplates/SolutionByCategory.aspx?NRMODE=Published&NRNODEGUID=%7bBE070174-CDA8-4628-8D04-7598F09C71E1%7d&NRORIGINALURL=%2fConsumer%2fCultures%2fen-US%2fProducts%2fThermostats%2fDo-It-Yourself%2fProgrammable%2fDefault%2ehtm&NRCACHEHINT=Guest
