First, I'm not a Realistic representative.
*** Following is for information only.***
* You can take a small low powered audio source and connect spare speakers to listen for output.
* or a multi meter to check which wires have some sort of drain in reference to each other.
* When volume is set to low you should be able to check for voltage output on wires. Note polarity. Try connecting only left side.
* Connect right side then check again.
* Sorry, unable to find (free) manual download. Every site listed has been blocked or deleted. You may be able to check ebay for manual. But like most old electronics this falls into "Antiques"
* 1987 Ad (lower right); http://fultonhistory.com/Newspaper%2018/Salem%20NY%20Press/Salem%20NY%20Press%201988/Salem%20NY%20Press%201988%20-%200537.pdf
* 1988 Ad; page 60 item 18 floating ground adapter; page 57, https://www.americanradiohistory.com/Archive-Catalogs/Radio-Shack/Radio-Shack-1988.pdf
* Wow, brings back memories of my first TRS-80. The computer that got me started in programing!
* Brick Cell phones!!!
Aloha, ukeboy57
* Additional information (but view at your own risk)
* The problem with "Registration sites" is your not sure if it's the right one or additional fee's required.
* Diagram (requires registration, with Fee?) ; http://www.gobbogames.co/realistic-equalizer-wiring-diagram.html
* Diagram (registration); http://www.falmouthproperty.co/wiring/realistic-equalizer-wiring-diagram.html
* Diagram(registration); http://www.crackthecode.co/realistic-car-radio-wiring-diagram.html
SOURCE: Hi! Looking for a manual on hooking up the speaker
Hey there ninja. I was not able to find a manual in English(Spanish only!!!), but I did find this site with a few PDFs that may help you out. It has the Features, Installation, Operation, Specifications, and Wire Connections, so it should help you out.
SOURCE: need the wiring diagram for
The main colors are:
Green - L+
White - L -
Brown - R+
Gray - R-
There are 3 sets of these. The ones with thinner wire are for high level input (from a stereo's speaker outputs). The two other thick sets are the speaker outputs to front and rear. They should've been attached to connectors labeled front and rear, if they aren't, you gotta find out through trial and error with the fader. Lastly, black is for ground of course, then the thin red wire is for 12V+ power (on with ignition), and the thicker red wire is power output to a deck, if you want it to turn on along with the amp/eq.
