Lands Phones Logo
s
stacey Posted on Aug 07, 2018
How do I change the name when I go into voicemail?
I can change my voicemail message, but when I go into check messages, I don't know how to change the initial name
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 05, 2008
SOURCE: model 4025
In the days before voicemail, Mitel had a "Call Me Back" feature that would light the MWI. We now use the MWI for voicemail, but the capability is still there. You can solve it several ways.
1. Go to the blinking phone and press the Messages button. One of those should be "Call me back". Press it and when the other party picks up, the MWI should turn off.
-or-
2. Look up the FAC for Message Waiting - Deactivate in your phone switch. On my switch it is *91.
Anonymous
  • 196 Answers
  • Posted on Sep 07, 2008
SOURCE: iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Anonymous
  • 192 Answers
  • Posted on Jun 27, 2009
SOURCE: Nortel T7316e help
dial your voicemail, put in your password, after you are in the voicemail, press 8 and listen to the prompts, it will tell you were to record your name for the company directory.
Anonymous
  • Posted on Jul 09, 2009
SOURCE: i don know how to change my messaging tone on my sidekick lx
to change txt message tone:
go to text message main screen then press the top left button.scroll down to settings and click. then scroll down and ull see "new message alert" and there u go.
to the same for picture messaging.
ring tone:
go to phone
click the top left button
scroll down to settings, then general
scroll down the incoming call. and clik on that and u will have options
Anonymous
  • 12 Answers
  • Posted on Jan 18, 2010
SOURCE: changing main voicemail message
This may be specific for my system, but hopefully it helps:
Connect to your voicemail (for us, we can either hit the voicemail button or dial 1650)
Once in, press #6, it will ask for a mailbox number, dial *9998, it will ask for a password (the default is 1234#)
Press 5 to modify messages.
Press 3 to record custom service menus.
It will ask you to pick which menu (1-100). Our day menu is 1, and night is 2. I'm guessing yours will be the same.
From this point, it becomes the same as recording a standard voicemail greeting. It will play the current greeting and you can press 1 to re-record it. Do so, and then press #. Press 2 to accept and you're done!
3answers
Wrong voicemail number
Call your services of the number company you have(like T-mobile).
And they will help you with that problem.
The voicemail light is fully lit(NOT FLASHING)it's not going away
First off we need to know what color it is.
Green-Dial "0" from the problem phone and that should clear it.
Red-Dial "Feature 99 Feature". If that does not work.
Leave a message in that users mailbox. From that users phone check and delete that message.
If neither of these operations work then you may have a bad port which means you may need a new station card. The part is an ESI(8)-U10-ETU, ESIB(8)-U10-ETU or an ESIE(8)-U10-ETU. The U10 might be different.
Let me know how these options work.
6helpful
2answers
I don know how to change my messaging tone on my sidekick lx
ring tone:
go to phone
1helpful
2answers
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
8helpful
We can't set the voicemail greeting to our own message
this way will take awhile, but this is the only way i know how to record a personal greetong so far:
  • on page 10 of the manual, it tells you to press and hold the 1/E key.
  • This will automatically connect you to your voice mail.
  • after listening to your messages or no messages, the robot lady says, "main menu."
  • after hearing this, pay close attention because she asks if you would like to be taken to "personal options" (press 4)
  • she will then ask if you would like to be taken to "greetings or recorded name" (press 3)
  • she will then ask if you want "to change [your] personal greeting" (press 1)
  • then she asks 3 options of what you can do (ie her telling people your number, then telling them to leave messages; you saying your name, then her telling people to leave messages; or what you asked about: recording your own greeting).
  • To record your "personal greeting," press 3
  • then she gives you directions for this, etc.
hope this helps and that it is the same for your phone... i have a propel A767... it took me a long time to figure this out, so you are not alone :D
Voice message, reprogramming extensions
How did you program the voicemail so a caller can not leave a voicemail to a particular extension? Line ownership? SO a call goes directly to a milbox?
How can you reprogram the voice message????? Which one, for a particular user or the main Auto attendant greeting????
You have to know the admin login to change a mailbox password.
For that, you need to know which voicemail system this is.
When you log in to check your mail, the lady says, "welcome to Partner......"
Please fill in the blanks.
1helpful
Lucent Partner 18D
Which voicemail do you have?
Partner Messaging?
Partner Voice Messaging?
Partner Mail VS?
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
4. Leave message
took this from a guide i found, helped me out
2answers
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
2helpful
2answers
Voice mail i6725 vtech phone
ACCORDING TO THE MODEL NUMBER THIS PHONE DOES NOT HAVE AN ANSWERING DEVICE. IF YOU HAVE VOICEMAIL - YOU MUST HAVE THE PHONE COMPANY'S SERVICE FOR VOICE MAIL. IF YOU HAVE A STUTTERED DIALTONE WHEN YOU HAVE MESSAGES THEN IT PROBABLY COMES FROM YOUR TELEPHONE COMPANY. CALL THE PHONE COMPANY AND ASK FOR INSTRUCTIONS TO CHANGE THE GREETING ON VOICEMAIL.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
