First, I'm not a JVC representative.
* Check your warranty. Call for support
* Contact; Website(includes manual); http://support.jvc.com/consumer/product.jsp?modelId=MODL029018
* Support; http://www.us.jvc.com/support/car/
*** The following is for information only.***
* Manual; https://pdf.crutchfieldonline.com/ImageBank/v20120222140500/Manuals/105/105KWR800B.PDF
* See page 4 step 3 to turn off.
* Perform Reset (page 3)
* Bad button(s). Your front display and control panel may need to be replaced.
* You may need to upgrade to current firmware. (contact to install)
* Demo (official); https://www.crutchfield.com/p_105KWR930B/JVC-KW-R930BTS.html?tp=5684&awkw=373095005473&awat=pla&awnw=g&awcr=226791677002&awdv=c&awug=9032739&gclid=EAIaIQobChMIpauyp8jZ3AIVi_5kCh00cwfyEAYYASABEgK3I_D_BwE
* Amazon (note: question option); https://www.amazon.com/JVC-KW-R800BT-Stereo-Receiver-Bluetooth/dp/B0079LGMB4
* Call JVC support 1-800-252-5722 for additional advice.
Aloha, ukeboy57
SOURCE: Demo mode Kenwood KDC-237
To turn off the demo you need to press the src button to put it in standby mode. Then press the menu button as if to change the settings and use the joystick to scroll right until you see demo, then turn it to off....
Do as above to allow you to enter AUX mode this will let you plug in your MP3 player to the input on the face and hear music through it ;)
hope this helps you
philzee
SOURCE: Aiwa CDC-X504Mp stuck in demo mode
This recently happened to my Sony, maybe it will help u
If this cd player has a removal fascia then try..
Carefully inspect the the electrical contacts on the fasica and the cd player. If it has got dirt on them then CAREFULLY CAREFULLY clean with cotton swab dabbed in cleaning Alcohol.
SOURCE: stuck in demo
I had the same issue and was about to give up.
cleaning, key combos and such didn't work out.
Solved the dirty way, as described some comments above:
"Just took the faceplate from the "push-menu" button and hit it against
a hard surface [not too hard but not too soft hits] and thats it, it
worked again."
ah, the good manners!
SOURCE: how do i take unit out of demo mode and set clock?
hold your sel. buton you use to get to bas, mid, and treble, and hole it down for a while till a new menu pops up. scroll using up/ down buttons till you see demo and left right changes the setting for it
I installed this new out of the box 5 years ago, into a vehicle that has always been a spare. I have never been able to get the unit out of demo mode. No combination of buttons puts the unit into a menu as described in the manual (ppg 23-25). And the demo cancel instructions on page 4 simply do not work. I've even done a hard reset to go back to factory specs, no change in symptoms.
