It light up
SOURCE: the bobbin thread is bird nesting on my viking
Make sure the bobbin is extended out of the bobbin case via the tension spring mechanism in the bobbin case. This provides tension for the bobbin unit. Check to make sure the upper thread has not "jumped out" of the take-up lever so that when the needle first touches the fabric the thread is still taunt and when the needle enters the fabric a small loop is formed right above the fabric and the eye of the needle. If these tips do not help suggest that you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
SOURCE: the bobbin is bird nesting on my viking emerald
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever and the bobbin is guided through the tension spring in the bobbin case. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
SOURCE: stippling for Viking emerald sewing machine
The switch in the back will lower the feed dogs.
If you need a manual - I found a PDF download by googling: viking emerald 183 manual
SOURCE: How do I move the presser foot on a Husqvarna
Not sure what exactly you need to know. Are you trying to lift the presser foot or change the presser foot to another one? If it is lifting, there will be a lever of some kind behind the machine. On one of my Husqvarna machines it was a big flat "paddle" shaped lever, not sure what shape it is on the Emerald machines. Lift the lever from the bottom upwards and outwards. Most Husqvarna machines have clip on-and-off feet. You just gently pull forwards on the foot (while the presser foot is raised) to remove it, then push the new one on making sure the small bar part of the presser foot goes into the clip on the presser foot ankle.
SOURCE: I need a straight stitch needle plate for a
Hi Valerie,
Have you checked the Husqvarna website for USA? Following is a link to a page where you may be able to identify your needle plate & possibly order the part through the Husqvarna website.
http://www.husqvarnaviking.com/us/accessories_search_accessories_search_details.asp?ItemNumber=412288102
Please let me know if you need any further assistance.
Best wishes,
Graemevm
