Question about Rio Radio Communications
Kia Rio 2012 radio lock!
The buttons on the sides of the screen they dont work, as well as the saved channels buttons. However, the radio it self is working, so it might be locked or sthing. Please advise...
SOURCE:
SOURCE: kia rio 2003 radio security code
call the dealer . Tech will give u a code to put into radio
Posted on Jul 20, 2008
SOURCE: LOCK CODE PLEASE ON 29"TRUSLIM
try zoom and then vol - and disable program lock from the menu.
Posted on Mar 28, 2009
SOURCE: Keys locked in 2003 Kia Rio Trunk
Go to the dealer they can give a copy of the key. Do not forget to bring personal ID and ID identication for car.
Posted on Aug 21, 2009
  • 31 Answers
SOURCE: kia rio key fob power lock/alarm problem
if the lights flash when you hit the panic button but the horn does not beep, then the alarm horn is bad. Vehicle has a second horn just for the alarm
Posted on Sep 17, 2009
noranda21
  • 1547 Answers
SOURCE: i have a 2007 kia rio i accidently reversed the
is it only the radio that dosent work there may be another fuse on the wire of the radio
Posted on Dec 05, 2010
2012 Kia Sorento passenger and rear power windows not working. Driver side is fine
It sounds like the window lock is engaged. There is a button with a picture of a window and an X. Make sure that it is in the up position.
Mar 13, 2017 | 2012 Kia Sorento
How to fix 2012 kia sorento camshaft sensor
replaced crank and cam sensor [Archive] - Sorento Nation - KIA ...
www.sorentonation.com/forum/archive/index.php/t-913.html
20 posts - ‎6 authors
replaced crank and cam sensors put back together cranked up very rough idle some tapping any ... 12-17-2012, 12:24 AM ... It's a 2006 3.5 Kia Sorrento. ... I found theproblem the SUV has a aftermarket alarm and remote start system I tripped ...
Kia Rio Crankshaft Position Sensor Replacement - YouTube
? 4:44
https://www.youtube.com/watch?v=hihQxMWuSFY
Mar 21, 2014 - Uploaded by Jason Roush
While looking for how to replace a Kia Rio crankshaft positionsensor, ... is on and i have a P0340 code, think this is theproblem? kia rio 2002.
Kia Sorrento/Sedona: 3.5 Litre Engine/Timing Belt/Crank ...
? 20:23
https://www.youtube.com/watch?v=CjaD_zYPrUA
Mar 29, 2014 - Uploaded by JamieJones TheCarMan
Repair and/or Replacement tips for timing belt, crank sensor,cam sensor, water pump and drivebelt ...
Crankshaft position sensor - 2003 Kia Sorento - RepairPal
repairpal.com > Questions > Kia > Sorento > 2003 Kia Sorento
Jan 20, 2016 | 2012 Kia Sorento Base 4dr SUV 2.4L 4-cyl....
I have an Hyundai i30 Dec 2012, the radio is different then the one in the car manual
Check google for most of the time if you goto the radio channel and press and hold the present button you want it will save they dont make them hard but new cars change every year
May 30, 2013 | Car Audio & Video
Reset oil change on a 2012 kia rio
From Kia's website.
"If you would like to reset or inactivate the maintenance system press the RESET button for more than 1 second. The display will change to "Engine Oil Service Message" mode.
You can move to items by pressing the TRIP button and select the desired item by pressing the RESET button."
Jul 27, 2012 | 2012 Kia Rio LX Sedan 1.6L 4-cyl. 6-speed...
Dash lights and radio dont work on my 2003 kia rio
Check fuses if not fuses could have a short in wiring
May 31, 2012 | 2003 Kia Rio
Kia Rio 06 radio needs to be reset. Code doesn't
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Kia servicecentre and get them to enter this code for you.
Mar 23, 2012 | Car Audio & Video
Kia rio key fob power lock/alarm problem
Sep 16, 2009 | 2003 Kia Rio
2003 Kia Rio radio station settings
Go to the radio station that you want, once there, push any of the numbered buttons and hold it there for a couple of seconds. That should set it.
Nov 18, 2008 | 2003 Kia Rio
Kia rio 2003 radio security code
Jul 19, 2008 | 2003 Kia Rio
Radio Communications Logo
98 people viewed this question
Top Rio Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Rio Radio Communication Expert? Answer questions, earn points and help others
