SOURCE: what type of HDMI cable
I would suspect any old HDMI cable would work. Those monster cables are great but overkill if you don't want to spend a lot of money.
SOURCE: VP-D351 need to connect with TV. What type of cable is required
Make sure your TV is a PAL unit. The easiest place would be to look in the owners manual. If you no longer have it, there should be a PDF format online. It should tell you what cable you need.
SOURCE: No audio when connecting Aspire 5315-2326 to TV.
Use a cable out of the headphone jack with an adapter to the red and white (left and right) audio jacks of your TV.
SOURCE: HI Guys. I just upgraded to
You're correct and that is exactly how I always recommend setup (contrary to what the manuals tell you). It makes no sense to me to run any signal through any electronics or interconnections that neither use it nor improve it. Hence, I have NO SOURCE VIDEO going to or through my receiver and NO high end audio going to my TV (which could just as well be a monitor with NO audio capabilities, right)?
Audio electronics should receive the BEST digital audio directly from it's root source.
The TV should receive the BEST video directly from ITS root source.
THAT is why most all high end A/V gear has separate audio and video in/outputs.
If that means you have to make some switching choices when using different sources, oh well. At least you won't have experience potential degradation from multiple hops or have to troubleshoot problems that could be anywhere in that chain.
SOURCE: Laptop S-Video to TV S-Video?
S-video and a 3.5 mini male to dual RCA male: http://www.bhphotovideo.com/bnh/controller/home?O=&sku=808831&Q=&is=REG&A=details From Laptop headphone jack to stereo input on TV.
