Question about LeapFrog Toys
How do I tune a didj now that leapfrog doesn't support the didj anymore? Is there another program you have to use?
It won't even let me wipe my didj because it isn't supported.The disc won't download either.
SOURCE:
  • 919 Answers
SOURCE: Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Posted on Feb 11, 2009
SOURCE: My son's leapfrog didj will
This happened with the first Didj we bought. Struggled to open the battery case with the stupid recommended dime. [Use a screwdriver instead - better able to push down the lever inside the case.] The 1st Didj never turned on. Totally dead. Exchanged it. The second Didj was easier to open compartment to install batteries and turned on immediately. Reommend you take it back.
Posted on May 04, 2009
  • 101 Answers
SOURCE: Can I download free games on my little sister's Didj?
apaarently not, usually you can find torrents like for the ds ps3 or xbox, but I couldn't find any for the didj
sorry
Posted on Jun 29, 2009
SOURCE: my didj screen says your didj needs a tune up
just connect it on the Leapfrog application then that would be it tune msg. will just disappear!
Posted on Oct 26, 2009
SOURCE: I have a mac and a leapfrog didj
Hey Jackiedonder!
I, too, have a mac and I've been having the same problem. In fact, I thought we had a faulty Didj, and I broke down and bought a second one. The second one is having the same issue. Unfortunately, Leapfrog doesn't address this issue online, and their customer service is only available on Monday from 9:00 -5:00 and Friday from 9:00 - 3:00. Seriously? I can't sit at work on the phone, trying to solve the problems with my child's game. I'm extremely disappointed with this product, and with the availability of help. It's turned out to be a big fat pain in the $@!. If you still have your receipt, I'd return it as fast as you can. Nintendo DS, anyone?
Posted on Mar 28, 2010
Power works; fan spins;light is on; promo screen works; disc won't read; disk won't spin
The most likely situation you have here is that the cd drive lens isn't reading, just because with a gamecube, it relies on that lens to detect if there is a disc inserted. Your best bet is to try and clean the lens with a que tip and some rubbing alcohol. Be gentle, only very gentle wipes back and forth in a circular motion, then dry it the same way. If that doesn't work, I can give you some tips on how to rip the thing apart and see if it is a connection inside somewhere
Sep 09, 2011 | Nintendo GameCube Console
Hi there I need 2 tune up my didj
Follow these steps To reset the Didj to factory settings and solve your problem:
1) Launch LeapFrog Connect
2) On your computer keyboard, press "Ctrl + Shift + R"
(on a Mac "Command + Shift + R").
This should bring up a window that says "Connect the device you would like to reset"
3) Connect the Didj and turn it on
4) Follow the on screen messaging to reset the Didj
5) Eject the Didj when the reset is complete
6) Recreate the profile on the Didj and then turn it off
7) Close and then open LeapFrog Connect
8) Connect the Didj and turn it on
9) You may be prompted the Didj needs an update. Accept this update
10) Get your parents to sign into the parent account and link a footprint to the current profile.
Mar 04, 2011 | LeapFrog Custom Learning Didj Racing -...
Hey Jackiedonder!
Mar 26, 2010 | LeapFrog Didj Console
Can't connect to computer. Downloads hardware etc. but when you click on it in my computers it gives message to insert disc (it shows as ''removable disc E and D''). Message on didj console is ''USB...
can't connect to computer downloads hardware etc.but when you click on it in my computers it gives message to insert disc (it shows as "removable E and D")
Message on didj console is "USB connected " Pleaase Help what should i do.
thanks and best regards,
raymond solas
Jan 08, 2010 | LeapFrog Custom Learning Gaming System
Didj
Follow this http://www.leapfrog.com/etc/medialib/leapfrog/support0/support.Par.24453.File.dat/Didj_Quick_Start_Guide.pdf
Also you must be aware that the program on question only works in Windows or Mac, no Linux support.
Sep 19, 2009 | HP xw4600 Workstation Linux Installer...
sorry
Jun 29, 2009 | LeapFrog Video Game Consoles & Games
Didj needs a tuneup! Bet when I plugged it in to the computer with usb it installed on the computer but the Didj never goes off downloading in progress. Ive tried on two diffrent computers and cant figure...
I bought my 2 for my grandsons for Christmas and both had the same problem. I Googled LeapFrog Connect and downloaded it. After you download it, plug the unit up to your PC with the USB cable that came with it. When you start LF Connect, it will tell you that there is an update for your Didj. Follow the prompts and you should not have any problems.
Charlie
Jan 19, 2009 | LeapFrog Custom Learning Didj Racing -...
Didj will turn on but Warning screen is just frozen.
I had the same problem. What you need to do is open the Leapfrog connect and then plug your DIDJ into the computer. You also need to plug it in with the AC adapter as this takes time and the first time I tried the batteries died. So plug it in or put new batteries in it. Now just leave it sit plugged into your computer with the Leapfrog connect program open. It took mine almost 2 hours just sitting on the white Warning screen then if finally connected and updated the software and is now working fine. Hope this helps.
Jan 18, 2009 | LeapFrog Custom Learning Didj Racing -...
Problem with didj
QUICK Summary:
- Download and install "Leapfrog Connect" manually.
- Wipe/reset your DIDJ (maybe...)
- Install the free game.
LONG Summary:
Like most people here on the forums and question boards, the didj hung or failed to download the update: "Download failed. Please try again."
I found that the .EXE from the CD, created a folder in the C drive "C:\Program Files\LeapFrog\log", where the file name was "Sniffer_*date*_*time*.log" Example: Sniffer_090102_1916.log
In this log file, there were two references to the remote files it had to download (in the display window, it says 101 Mb. So the two files below add up to about that much):
http://download.leapfrog.com/leapfrogconnect/PC/didj/DidjPlugin.exe (78Mbs)
http://download.leapfrog.com/leapfrogconnect/PC/UPCInstaller.exe (25 Mbs)
The DidjPlugin.exe is the "Leapfrog Connect" installer, while "UPCInstaller.exe" is the free Jetpack Heroes game.
I cancelled the hung or timed out program launched from the CD, rebooted the PC, and then proceeded to download these two files manually.
After downloading these two files, I double-clicked each one. There was no dialog box or confirmation or license agreement page, destination folder, etc, etc, etc. This was a 'silent' installation, with
no prompts (save for the Windows security prompt: "Are you sure you want to run ...exe?"
I then proceeded to wipe the handheld (because it was stuck on "Downloading Update, please wait...).
Launch Leapfrog Connect:
1) Press the "Ctrl + Shift + R" keys in sequence and hold them down.
2) This should open a window that says "Connect the device you would like to reset".
3) Connect the Didj.
4) Eject the Didj when done.
5) Recreate your player profiles on the Didj and connect again.
I could be wrong, but wiping the didj did not erase the free game. I don't remember, but there was a point to sync the didj and then the game was there... Anyways...
After restarting the didj and creating a new profile, connecting to Leapfrog Connect, the didj should be good to go.
I do have a couple questions:
Why only have a small 5Mb self-extracting installer on the CD? Why not include the larger (75-78Mb) "Leapfrog Connect" on the CD?
Why not have the free game ALREADY installed on the didj? That way, when it comes out of the box brand new, you get to start playing right away...
Thomas
My (kids) PC specs: AMD Duron 1.2 Ghz, 768Mb RAM*
Windows XP, Service Pack 3
Dec 27, 2008 | LeapFrog Custom Learning Case
Toys Logo
242 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
Keith Koene
Crystal Walters
Crystal Walters
Level 1 Expert
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
