Question about Polaroid Televison & Video
I am trying to determine whether the power supply in a Polaroid UHD TV set is defective. All voltages are good except I don't know what the LED voltage is supposed to be. Can you tell me? Thank you.
TV Part #DE550M3N4AU-YA4 Power supply Part # MIP550D-TF1
  • Polaroid Master
  • 18,060 Answers
It is dependant on how many LED's are present in the back light LED array. IT can be 35 to 60 volts. In most cases the power unit does not fail, the LED's do because they are pushed to their maximum output for the illumination of the screen. All it takes is one LED to go bad and the rest wont come on. The diagrams for the unit are not posted
Posted on Aug 05, 2018
SOURCE:
jomaru
  • 337 Answers
SOURCE: Flashing LED on front panel
The place is call wwww.servicemanuals.net ,you can get it download or a paper copy,for this set I dont know the price but it will give it to you when you put the model number.Check for shorted horizontal output and loose conections,sometimes intermitant conection damage this transistor.Be careful
Posted on Oct 04, 2006
Benimur
  • 6966 Answers
SOURCE: lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 26, 2008
  • 95 Answers
SOURCE: Hello only on screen
On the power supply board I replaced CAP C226 as per another poster and the problem is solved. It is a 470 uF, 35 VDC capacitor. Bought one at Radio Shack for <$1.50 USD. Radio Shack part number is: 272.1030.
Posted on Jul 23, 2009
xptareq2000
  • 1447 Answers
SOURCE: power supply output voltage from the three wires.
please you buy any old printer same model
or reaper it change fuse
Posted on Aug 27, 2009
  • 63 Answers
SOURCE: i DON{T KNOW THE SPECIFICATIONS FOR THE POWER
12V, www.ebay.com, item # 280362473044
Posted on Sep 29, 2009
Where to find main power for vidao Mip550d-ste
Are you looking for a power supply board?
Nov 08, 2017 | Televison & Video
Have flat screen tv has sound no picture
Back - light problem? Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 24, 2016 | Element Electronics Televison & Video
What is the most common problems that occur in Seiki tv model # SE50FY10 when the screen does not turn on but the power light is on?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 06, 2016 | Seiki Televison & Video
Se50fy10 backlight not working
This is an exact problem that I am facing with my Seiki 50" TV. From my research, here are the probable issues:
1. Main Board/T-Con Boards are fine
2. Power Board : MIP550D-5TB could be defective - most probably the culprit. There is a power test to try but w/o schematics, it is not possible to identify component
3. If Power Board replacement does not solve, it is the backlight LED strips that are defective - tought one to replace.
Will update this thread at a later date.
Sep 18, 2015 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
What is wrong with my eleft502
What you are describing sounds correct, but there is never any guarantee with repairs until you affect them.
Jul 02, 2015 | Televison & Video
Co510 code
One of the parts in the list below are causing "Low fuser teperature"
C0500: Warming-up failure
C0510: Abnormally low fusing temperature
C0520: Abnormally high fusing temperature
Relevant Electrical Parts
Fusing Roller Heater Lamp H1
Fusing Roller Thermistor TH1
Fusing Roller Thermostat TS1
Fusing Roller Heater Lamp Fuse TF1
Side Cover Interlock Switch 2 S3
Power Supply Unit PU1
Master Board PWB-A
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 03, 2011 | Minolta Di351 All-In-One Laser Printer
Je cherche pour key des chenes / M6+TF1+ACTION/
contact yahoo mail support center, or use help at yahoo mail
Dec 02, 2010 | Yahoo Mail
Televison & Video Logo
73 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
