Question about Frigidaire Microwave Ovens
Frigidaire microwave FPBM3077RFA - What does E-11 code mean?
  • Frigidaire Master
  • 9,418 Answers
Posted on Aug 05, 2018
SOURCE:
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Aug 18, 2017 | Kenmore Microwave Ovens
We have an error code of E-11. We are trying to set this product to demo mode for our in store display
I appreciate your post, Wendy!
Based off the information you have provided your Frigidaire microwave is displaying an error code of "E-11". An "E-11" stands for the gas-sensor is open, this could be an issue with your sensor harness, connections, or gas sensor. I would recommend performing a reset on your microwave and you can do that by flipping off the household circuit breaker for at least ten minutes. If that does not resolve your issue you may need to seek assistance from a professional technician for proper repairs. This will help you avoid any unnecessary part purchases. -Matt
May 30, 2015 | Frigidaire Professional Over-The-Range...
I have a se or 5e code what is it
Thank you for your post, friend!
I understand that your Frigidaire microwave is displaying the error code "SE" or "5E". I have researched and the error code seems to be "SE" which means keypad is stuck. In order to remove the error code the keypad would need to be replaced.
Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Microwave Ovens
Unlock frigidaire microwave model FFMV164LSA
Good Afternoon Friend,
I understand you are trying to unlock your Frigidaire microwave, model# FFMV164LSA. This has two different meanings to me. First, if the door is locked and will not come open, I suggest contacting your local authorized technician. Secondly, the control lock is on. If the control lock is on, you will need to press and hold down the "Stop/Cancel" button for 3-5 seconds, to unlock it. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FMT118E1W Microwave Oven
Indicater light shows S. E. what does it mean?
Good Afternoon Sandra, thank you for allowing me to assist you!
Typically error code SE indicates a shorted key on the keypad. Try unplugging the microwave or flipping the household circuit breaker off first. Wait approximately ten minutes and turn the unit back on. If the error code continues to display, then I recommend contacting a professional to make a precise diagnosis.
Oct 05, 2013 | Frigidaire Over-the-Range Microwave
Jenn-air jmv8208bas e-11 error code
test this problem and fix it. God bless you
E11 A, F CT oven; latch switch problem
Jul 22, 2013 | Microwave Ovens
My Frigidaire electric range has the f-3 message error what does that mean
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking an oven Temperature Sensor .
Fault Code F1 F3 F9 Dr
Dec 04, 2010 | Frigidaire Microwave Ovens
Microwave Ovens Logo
936 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Jaime Hernandez
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
