Question about Riccar Vacuums
I have a riccar supralite vacuum . the bag is new, suction good but when you turn on the machine it makes a loud noise- and automatically short circuits. i reset the switch and it blows again
  • Riccar Master
  • 1,581 Answers
It also could have a broken impeller but that won't usually cause it to short out but it might if it can't turn at all.
Posted on Sep 06, 2018
  • Riccar Master
  • 18,023 Answers
The brushes in the motor are worn to the point that they are not working, it is shorting out.
Posted on Aug 05, 2018
SOURCE:
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
  • 55 Answers
SOURCE: noise
What does this noise sound like? If it's a squealing noise, chances are that it is a belt going bad. You can purchase a new belt at your local Sears, or probably even your local grocery/department store. The vacuum belt is easy to replace and inexpensive. Instructions for belt replacement are in the owner's manual, or sometime on the belt's package. Hope this helps... Please take a few seconds to rate how helpful this suggestion was. Thanks and good luck!
Posted on Sep 12, 2008
  • 13 Answers
SOURCE: Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Posted on Oct 03, 2008
chrispurs1
  • 372 Answers
SOURCE: Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Posted on Oct 16, 2008
  • 61 Answers
SOURCE: Hoover started to make loud noise
It sounds like a bad motor. Take it to a local vac shop and they should be able to order the motor for you.
Posted on Apr 15, 2009
I have a Riccar Supralite Cordless that is clogged. I just replace the bag but whatever the vacuum picks up, it seems to be pushed back out. Is there a way to get to the vacuum tube to unclog it?
Start by checking the suction opening by the brushroll. Then remove the screws and take the nozzle cover off. Remove the cover to be able to inspect the impeller for clogs or debris. Pull the motor if necessary to gain access to the lower end of the suction tube/handle.
Sep 03, 2018 | Riccar Vacuums
I purchased a riccar 2150L second hand with no information. I have a 10yr old riccar supralite and love it! But the 2150L looks older. I am curious what the age of riccar 2150L vacuum is.
Your m
2150 L is likely 25 to 30 years old. The first Riccar vacuums were made in Japan. Your was likely made in Taiwan. Production of most models was brought to St. James, MO 20 years ago. Filters, bags and some parts are still available from your local Riccar dealer, or from ThatVacGuy.com
Dec 14, 2017 | Riccar Vacuums
Riccar 8995 no suction
If it's been over a year since you've replaced the belt that is the first place to start. Stretch belts lose elasticity and will still turn the brush roll but when the brush roll is lowered to the carpet it may not turn fast enough to pick up properly. If you have good suction at the end of the hose check to make sure there is not an obstruction in the tube where the hose goes into the bottom of the vacuum to the brush roll. Make sure your filters are replaced at least once per year and the bag is not full or has a lot of fine powder dust in it which can clog the bag.
Jun 13, 2014 | Riccar 8955 Upright Vacuum
Riccar 8995 no suction in hose
drop a quater thru hose make sure it goes thru
May 18, 2014 | Riccar Vacuums
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
Why does my riccar supralite vacuum makes a loud rattling noise like the roller is banging around?
You have something wrong with your brush roll or you have damaged the fan. Remove the brush roll and belt and turn the vacuum back on, if the noise is gone it is likely something wrong with your brush roll, if the noise persists you probably have a broken fan. You have to remove the motor and fan housing after removing the top cover, unscrew the bolt holding the fan on and install a new fan (you can get one from any Riccar or Simplicity vacuum dealer)
May 15, 2014 | Riccar Vacuums
Riccar supralite makes a loud rattling noise like the roller is banging around
If the noise is not something in the brush roll or the brush roll bearings or shaft is damaged the impeller may have something stuck in it or it may be broken.
No suction in hose
There is most likely something stuck in the hose.
Jun 06, 2013 | Riccar Model RC1100 Canister Vacuum...
Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
Lost suction after I changed the bag and cleaned the air filter
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
May 20, 2009 | Riccar 8955 Upright Vacuum
Vacuums Logo
93 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
rebecca curry
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
