SOURCE: philippe starck ph-1071
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps,
SOURCE: cannot set the date on the casio tachymeter
wen u twist th big thing do it twice and press the top button to set dates
SOURCE: Bought a new Casio Edifice
It could be that you need to unscrew it before pulling it out (at feature that is sometimes used to give a better seal).
Turn the crown anticlockwise about 1/4 -1/2 a turn then pull.
Testimonial: "Thank You davidtolond. Your soultion was helpful. I am able to setup the time and date. Thanks for your help."
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in
PDF format.
To download a PDF file, enter the four-digit (or three-digit)
module number marked on the back cover of your watch.
