Https://www.orbitonline.com/help_center?stPage=guideListPage-1
This is the location of Orbits Product Manuals! Hope this helps
SOURCE: Solenoid on one station, sprinklers on another, cant turn both on
the should be a pump or master solenoid connection inside the controller
SOURCE: sprinkler station drives another station by mistake
change the control valve for line 2. the coil is not pulling the plunger all the way in.
SOURCE: I have a Rainbow RB1
Hi Andy, I think I have found a solution to your problem. With the time and day set, clear the program for each station by selecting Start 1, station 1, off, and repeat for each station. Then select Start 1, Station 1 and hold down the Day button. The Mon for Week 1 of the cycle should appear. Then if you hold down the Off button, the Mon will scroll down to your allocated watering day of week 1 eg Sat. Then, Hold down the Day button again until the next day appears eg Sun in my example above. If you again hold down the Off button, that Sun will scroll through to your allocated day of the week in Week 2. Hope this helps. Next job will be to change it when restrictions change in summer! Martyn (Bassendean Perth)
SOURCE: How do I get a
Welcome To FixYa
I was able to locate a manual for your timer. Go to this website
http://www.orbitonline.com/lib/media/57894-24%20rA%2812%291.pdf
Please note that this is in PDF format which means that your computer needs to have adobe reader installed. If you dont have that you can download it here
http://get.adobe.com/reader/
If you have further questions just reply back and I will be happy to assist you
Hope this Helps
SOURCE: I have had my hamilton
On your machine there is maybe inside water reservoir a hose or tube that goes down to bottom, or suppose to go down to bottom, to **** up all water. Look inside and see if hose is going all the way to bottom, maybe it got hung up or crooked. Please let me know, glad to help, thanks mike ( mr bean man )
