Question about Frigidaire Kitchen Ranges
I have a new Frigidaire Electric Range with regular and convection backing. When I turn on "bake" the fans runs, is that appropriate. I thought it would only run in "convection" mode.
2 Suggested Answers
SOURCE:
protek480
  • 1730 Answers
SOURCE: Kitchenaid electric convection range - preheats
Put an oven thermometer in the oven on convection bake and check the actual temp inside. I'll bet it's not maintaining the correct temp in convection.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 25, 2009
Motor working sound when our new Frigidaire electric range is heating to selected temperature. Is this normal?
some fan assisted ovens turn on the fan to get up to temperature, its an energy efficiency thing, also mean pre heat is quicker. if you need more info on this unit here is web page
http://www.frigidaire.com/Owner-Center/Product-Support--Manuals/?productCode=LGEF3045KF
hope this helps you.
Jun 11, 2017 | Frigidaire Kitchen Ranges
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Fes367dsa fan runs while baking but it is not a convection oven
Chris Lindstrom,
I understand that you have a fan running while you are baking. This is a totally normal function of your applliance. A cooling fan may automatically turn on and off to cool internal parts. It is normal, and the fan may continue to run even after oven is turned off.
-Best Regards-
Jan 15, 2014 | Frigidaire FES367 Electric Kitchen Range
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid electric convection range - preheats just perfectly in regular bake mode, but takes forever on convection bake. This model has 3 elements - broiler, lower covered element and a convection...
Jul 24, 2009 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Broiling and Baking Element Stopped working
the thermostat is bad that's the one that turns bake and broiler elements,but before you replace anything check for power on wires connecting to the elements.
Dec 09, 2008 | Frigidaire PLES389D Electric Kitchen Range
Frigidaire Gas Range with Convection--fan does not turn on
The convection fan is wired through the door switch make sure your door switch is o.k. before replacing the board or the fan. Please have a local service tech check unit if you have to get into any electical checks. good luck
Dec 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not stay on when baking regular none at all, convection have to set a couple of times
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
Jul 05, 2008 | GE JBP90 Electric Kitchen Range
Convection fan does not turn off when door opens
fan is operated by a door switch which has jammed. as i recall, this is located inside the rhs side panel
Jun 16, 2007 | Frigidaire GLEF378 Electric Kitchen Range
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
