2 door Silver Electrolux fridge freezer
That is not a good model number. Is it a top mount freezer or side by side? Generally in electrolux the freezer is what cooks the fridge, if fridge is not cooling, it could be several things causing it.
1. Damper not opening
2. Damper has ice build up
3. The return has ice build up
4. The freezer evap assembly is not defrosting to allow air flow.
5. The evap fan is not turning.
SOURCE: FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
SOURCE: HotPoint model HSS25GFTBB fridge warm freezer cold?
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
SOURCE: Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
As applied to your concern:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
