SOURCE: Hello there, good day Sir I am currently using one
Press and hold the control lock button for 5 seconds to clear the machine.
SOURCE: Toshiba auto washing machine model
Hi.
E2 is not an error code. It means that the Spin only mode has been started and that the cycle is now over.
To reset the machine try disconnecting power (trip circuit breaker), connecting back, then hold down the Super Spin Dry button while you start the machine at the same time (press On while holding the other button). You should hear three beeps and the machine will be reset to initial settings.
SOURCE: I have a Toshiba Washing
aoa may machen is toshiba problem is timer not work and led blinking you gev meen anser waht porblem hai thanks
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
SOURCE: toshiba washer malfunctioning model aw 9770 sb showing an error of e7-4
Owner's manual troubleshooting may give you an answer.
Google make model possibly serial year. You may find someone with the same problem and the solution. Usually MFG customer service is helpful. If fairly new local dealer may be helpful.
