Replaced gasket, both types didn't work
First, I'm not a Pasquini representative.
* Check your warranty. Call for service
* Check with coffee vendor (may have a espresso tech.)
* Support; https://pasquini.com/pages/support
*** Following is for information only.***
* Service should have fully tested unit prior to releasing it to the owner.
* Check the portafilter(s) Brand. (Just because it worked earlier, the new gasket may be correct and the previous gasket was another brand)
* Check the portafilter(s) baskets for dents, flat areas on lip, and clogged holes in baskets.
* Replace worn dump box rubber bumpers (the part that gets hit with the portafilter.) If the metal bump support rod is exposed then this metal to metal contact will damage the portafilter and basket.
* Check for the correct (brand) baskets. Some are flat edged while others have a rounded lip.
* Check for portafilter "Port" if it's clear of obstructions (old coffee)
* Some portafilters come with a built in flow restrictor that needs calibration or cleaning.
* Re-check group head for miss mounting, damaged gasket or group head.
* Check if leak has coffee in it (leaking group head at or near gasket)
* Check if leak is clear. (leaking before group. Solenoid group valve.
* If leak happens all the time even without dosing then check the group head plumbing for leaks.
* Testing after gasket change( Note problems mentioned); https://www.youtube.com/watch?v=cEmIsKFB7So
* Shot Demo; https://www.youtube.com/watch?v=htJEdA_nAIs
* Cleaning; https://www.youtube.com/watch?v=aueYkiAamSs
* Back flushing; https://www.youtube.com/watch?v=8PsFa7exm2I
* Vendor's review; https://www.youtube.com/watch?v=jZiE4h5_X5c
* Vendor's compare; https://www.youtube.com/watch?v=IxsyrnVM8ws
Aloha, ukeboy57
PS; If everything checks (and new) but still leaks. Have the Service tech double check the parts in Group head assembly and the portafilters used as there may be a part miss match (wrong brand used.) I've found that group gaskets come in all sizes and thickness even from the same company. It may look the same but if you take a micrometer to check, it's different.
SOURCE: need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
SOURCE: After several failures, I replaced
Hi
Check the wire on the water reservoir to make sure that it is properly connected.
Check to make sure the wire connection is clean and making good contact.
If the machine turns on the connection is dirty, so you will need to remove nut and clean.
There is a level probe on top of the boiler (actually 2) The right one (yellow wire) is the low level probe and it will not let the boiler turn on unless it sences water at the probe. If it is scaled it can't tell if there is water in the boiler and the element will not heat. Remove and clean the probe.
SOURCE: pasquini service in washington dc
Hi
If they are blinking slowly check this. Check the wire on the water reservoir to make sure that it is connected. You can try grounding this wire and see if the machine responds.
Water level may be low in the reservoir. Are you using distilled water or reverse osmosis water. Don’t. The computer can’t tell if have water in the reservoir, because it need’s minerals to conduct the small current for the computer. If they are blinking fast you may need a new computer.
SOURCE: Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
SOURCE: My pasquini livia machine is
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
Boiler end gasket
11
Expanse Valve
21
Group gasket
Heating element
12
Drain
22
Refill solenoid
Gasket for above
13
Pressurestat
23
Group touch pad
Steam + water valve
14
Main switch
24
Drip tray grill
5
Pop off valve
15
Group
25
Water flow meter
6
Bleed valve
16
Group solenoid
26
Drip tray
7
Water level Probe
17
Group handle
27
Basket
8
Auto refill relay effect
18
Filter basket single
28
Steam-water valve knob
9
Heater exchanger injector
19
Plastic gasket
29
Manual refill valve
10
Heat wand
20
Site glass
30
Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
