SOURCE: sony tv red flashes
LED flashes of 8 times are indicative of a "High Voltage Error" which means something along the lines of "T8005 is faulty. (D board)" according to the service manual. Most likely it will need a professional to look at it. A link to the service manual is here: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
SOURCE: 13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
SOURCE: light flashing 13 times on sony bravia KDL-46x3100
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
SOURCE: My sony bravia KDL-52W3000 turns on makes a hiss
This is a fairly classic switchmode power supply, the protection circuitry inside has sensed a severe potential problem, and is shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done
