SOURCE: I was using the pressure washer and it stopped
This problem, where the unit continually switches on and off when the handgun is closed, is quite common. Unfortunately it has at least six different possible causes, only two of which are easily checked.
The first thing you can do is look for leaks. Even the slightest leak will cause this pulsing because the unit gets up to pressure, switches off, loses pressure, switches back on again, comes back up to pressure, switches off... and so on. This repeated switching is not good for the motor and should not be allowed to continue for longer than necessary to observe what's happening.
So... 1. Does the handgun shut off completely, or does it drip? If it drips, it may simply be because a seal has failed. The handgun can be dismantled, checked, and any defective parts replaced; be sure to lubricate O-rings with silicone grease when reassembling. As a last resort, the whole gun may need to be replaced.
2. Are there any visible leaks at the high-pressure hose screw connections? If so, most likely an O-ring needs replacing - again lubricate the new one well with silicone grease.
3. If there are no visible leaks, either from the gun or from the connections, all other possible causes are internal within the cylinder head or control head of the pump. New parts will be needed and this normally calls for a professional repair, although it's not beyond the scope of a truly competent amateur.
I hope this helps. Any further questions, just ask! Please remember to rate this response.
SOURCE: Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose
2. Connect the water supply and turn on
3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
SOURCE: new Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
