SOURCE: My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
SOURCE: hp4345 51.10 error i have replaced the laser unit,
It's still a laser beam detect error, you need to make sure the safety shutter is opening when the door is closed. It blocks the beam from your eyes and also the beam detect sensor. If all is good, you could have gotten a defective laser.
SOURCE: Microsoft Force Feedback 2 joystick - Lost Power Supply.
Hope this helps.
Part No. 96749 (Maybe Ebay?)
Input: 230V~ 50Hz
0.15A
Output: 12V 1.3A
SOURCE: I have a Hampton Bay 300W power supply for outdoor landscape.
"The wire with a light" is a not light bulb. That is your photocell. At dark will turn your system on if you select thta feature.
I have tha same power supply. In my case "check circuit" light is on. I need a manual so I can troubleshoot. Any Ideas?
