Just get (found) this PC, or it just happened out of the blue???
history matters.
no OS stated> edge 2 what, it has numbers after the 2.
maybe someone changed the Language on your PC, (prank)
why not grab a (barrow) USB keyboard from anyone. plug it in....
plug it in, if the keys fail now the OS is set to any of 50 different languages.
google microsoft.com, for setting that LANG. in your unstated OS.
XP,VIsta,w8,w10? they have the answer there, they built the OS.
in w10 in the run box type settings
in that page click time and LANG.
I see united states in my box, do you see yours?
there is also there page for changing keyboards, for 50 _types
even QWERTY , AND odd DEVORK BOARDS, AND MORE.
endless choices it seem on keyboards and language.
you can also set up 2 langages, add a language.
then switch fast, by clicking task bar ions.
Most likely the keyboard is faulty.
SOURCE: Brother ML-500 Typewriter Typing the wrong characters
The printwheel is not in correctly. the printwheel has a bent spoke or the printwheel homing sensor needs cleaning. Lawrence
SOURCE: fn key active
This is not because Fn key its Num Lock key that changes jkl to 123. Just turn Num Lock button off.
SOURCE: keys on keyboard typing wrong characters
Instructions for Windows Vista
Instructions for Windows XP
SOURCE: 2 letters get typed while pressing one key
try other keyboard if the problem don't appear that's hardware problem, may be the rubber under the key responding each other, it is easy to open the keyboard casing then you can check the problem inside
