Televison & Video Logo
Doug Mulligan Posted on Aug 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you repair a proton 320 clock radio
Purchased around 30 years ago
Marvin
Level 3:
Top Expert:
  • Proton Master 85,242 Answers
  • Posted on Aug 02, 2018
Marvin
Proton Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29056633
Points
266281
What is wrong with it.
5 Related Answers
Anonymous
  • 666 Answers
  • Posted on Apr 13, 2010
SOURCE: Proton 320 clock radio won't stay off. Comes back on by itself!
check power switch if not block and i good position. and also monitor by multitester if the continuity of that switch cut in off position.
freetek
Steve Allison
  • 5569 Answers
  • Posted on Jun 28, 2010
SOURCE: I have a ten year old Proton Clock Radio RS-330,
The display itself may not be the problem which may be related to the power supply for it instead. Some technical skills and a decent multimeter is the minimum you should have to determine the source of the problem.
If you are looking for a local service company, you should always post your ZIP code so a tech in your area is likely to respond.
Anonymous
  • 15 Answers
  • Posted on Oct 05, 2010
SOURCE: Lost my 'off' ' button on my Proton 320 clock
No need to worry, you can buy adjustable knobs and at radioshack and ebay. However if the button broke off you need to go in and replace it.
Cytherian
Gary
  • 126 Answers
  • Posted on Nov 07, 2010
SOURCE: My Proton 320 radio has stopped working, although
Unfortunately, Proton discontinued these a very long time ago. There is not very much information available about them. The cause for the radio malfunction could be a number of things. One possibility is the switches. There is a foam gasket around the switches that degrades over time. If pieces of it get stuck inside the on switch, or lock the off switch, it would prevent the radio from working. You could try taking it apart and use a can of compressed air to clean out the switches. I had a problem with the radio turning on all by itself and the compressed air cleaning solved it.
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Jan 23, 2011
SOURCE: I must have pressed the
when you set the alarm it is activating by itself ...see that you have the button that will set it to go to radio or buzzing noise..and in the back it has a knob for a separate volume on the alarm I think this is what you have lower and the alarm is not heard even if it kicks in ..
let me know if that is the issue or I should see further ..
I must have pressed the wrong button on my old but excellent Proton 320 clock radio because the radio no longer comes on at the time set on its alarm. The radio is fine when I just turn it ON; it goes...
2helpful
My Proton 320 radio has stopped working, although the clock function still works. Is this a simple fix? Where could I find a manual?
Lost my 'off' ' button on my Proton 320 clock radio!
I have a ten year old Proton Clock Radio RS-330, now Sangean RS-330. The flourescent display seems to be about half out, and the time display is barely visible in the dark. Can this be repaired, and by...
1helpful
I have a 25 y. Proton 300 radio, which until recently has been flawless. It now reverberates and seems to have "ghost" sounds, even when sharply tuned. What's wrong????can it be fixed???where could I...
It sounds like the tuner is out of alignment. A number of things can cause this kind of problem. However, a realignment is a very costly proposition, especially when considering the used value of the Proton 320. If you really like this radio, you might want to try buying a used example off of eBay. They come up very frequently. Only... be selective. Don't pick anything from a seller without a lot of good feedback. And don't overpay ($50 tops).
1helpful
2answers
The FM tuner picks up only a few stations and those are very faint. Two other Proton model 320 radios work fine in the same area. I live on Long Island where the reception is rather strong.
The tuning module within the radio is getween the base circuit card and the display. A shot of tuner cleaner into one of the ports will usually bring back the FM performace (I just got done diong my own). Also, it goes without saying that you need to make sure your radio still has its antenna wire and that the vacuum didn't eat it. If this is beyond your skill level, find a computer geek (there are few radio geeks any more). Commercial repair would cost more than the value of the radio.
1helpful
Tuning drifts
1helpful
2helpful
2answers
Tuning lamp on Proton 320 clock radio
The bulb is a small electronics bulb on the left side of the lexan display cover and it is covered with an insulated foil tape. Measure the voltage on the bulb with a voltmeter and go buy a replacement from any electronics supply place or radio shack.
Top Proton Televison & Video Experts
matt martin
matt martin
Bob Kirkwood
Larry
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
